Old 10-08-2013, 04:40 PM
Miraphone186's Avatar
Miraphone186 Miraphone186 is offline
Pinging or knocking when hot
Yesterday I got off the freeway, and when I took the first turn onto the surface streets the engine started making a pinging/knocking noise right as I turned, and stopped right after. I drove down the road a ways and it came back for a little bit while I was accelerating uphill. It came back for a little bit once again when I was turning for the last time onto the street I live on. Oil pressure is about 9 psi hot idle and I know it isn't great and I'm praying it isn't rod knock and just pinging from carbon buildup or something, but I've never had a car that did either so I don't know what either sounds like from inside the car. Thanks guys.
1990 Grand Wagoneer DD
Old 10-08-2013, 05:07 PM
DanHS's Avatar
DanHS DanHS is offline
I can't even describe just what pinging/detonation sounds like, it's like a clattering sound when accelerating, not the same as the deeper clunk of something in the crank.
What was your engine temp when you got off the highway? How is your ignition timing setup, how much advance and are you using ported or manifold vacuum advance?
My FSJ pics
FSJ Grille Identification
Old 10-08-2013, 05:30 PM
To be honest I haven't touched any of that since I got the jeep. It's all stock, I know that much. The temps are okay, It has a 180 degree thermostat so it runs a bit cooler than normal anyways.
Old 10-08-2013, 05:37 PM
pinging aka detonation
sounds like marbles in a coffee can
think low oil pressure and valvetrain noise on steroids.
BAD gas will do it, just fill up recently?
Old 10-08-2013, 05:55 PM
It sounded kind of like a diesel type clatter but only on one cylinder or something. I filled up about a week ago.
Old 10-08-2013, 06:54 PM
serehill serehill is offline
Gone,Never Forgotten.
yup
That is clatter sounds like cheap gas or the distributor is too advanced.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 10-08-2013, 07:38 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Take a standard claw carpenter's hammer and bash it rapidly against concrete. That's what detonation sounds like.
Check the EGR.
Old 10-08-2013, 08:46 PM
brielly's Avatar
brielly brielly is offline
Run down the tank and fill up with quality fuel. Maybe run some techron or similar to decarb the motor. Seafoam is an option as well. If that does the trick you're good to go. If not you may need to back off the timing a bit or run higher octane fuel.
For Sale Custom built reproduction Rhino Grilles http://www.ifsja.org/forums/vb/showt...24#post1676924PM me for details or email rrielly@verizon.net
1982 Cherokee Chief 258 6 cyl, AX-15, NP208, mopar mpfi, hydroboost brakes.
1983 Jeep Cherokee Laredo 258 6cyl*SOLD*
Old 10-08-2013, 09:02 PM
I managed to get a video after battling it out with all the idiots coming home from work. The sound is right at the beginning, it's not very loud but it's there.
http://www.youtube.com/watch?v=LgohsxxJkCU
Old 10-09-2013, 06:47 AM
yeah
Either bad gas advance timing or running too hot. The audio is not definitive to me at least.
The noise I am hearing does sound like pinging. Rod knock is low frequency pinging is high frequency
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 10-09-2013, 09:47 AM
JeepWrencher JeepWrencher is offline
It never hurts to check the timing. You can do that and know for sure that your ignition is making the fire at the right time.
Rod knock sounds alot like a gorrilla sitting in your engine bay and pounding on the firewall. It isn't subtle and if that were it you would have pulled over the first time you heard it not kept driving.
I agree on putting some good gas in it but check the timing too.
1983 J10 Short Bed
AMC 360 / 727
230,000+ miles and counting
No mods just keeping Darkhorse running
Old 10-09-2013, 10:32 AM
video isn't any help too much background noise
get one with the engine warmed up and idling, and under load like in gear w/ your foot on brake
Sounds like you have multiple issues.
Do you have a bad exhaust leak?
Old 10-09-2013, 10:41 AM
No, but the speedometer makes a weird noise for some reason, that might be what you're hearing.
Old 10-09-2013, 10:44 AM
@ any rate get a better vid, or swing by a local engine rebuild shop they'll tell you what you're hearing.
Old 10-09-2013, 12:15 PM
FSJunkie's Avatar
Very god point. Sometimes the speedometer cable can make a rattling noise that sounds a lot like ping.
Old 10-09-2013, 02:43 PM
I just put in Shell 89 and a couple bottles of that techron stuff, I'll see how it runs tonight on my way home. I have a sneaking suspicion that it's carbon that's to blame because I mostly do city driving anyways.
Old 10-09-2013, 02:59 PM
Sheesh man, quit looking for silver bullets and throw a timing light on it. 5 min job.
Old 10-09-2013, 03:14 PM
I would if I had one. I'll go buy one right now.
Old 10-09-2013, 03:47 PM
Not trying to be an asshat but guess so far you don't even do your own tune ups. If you plan to in the future and maintain your vehicle a light should be in your toolbox. Kinda basic tool. If maint isn't your thing, pay a shop or get a neighbor to help. I'm assuming since you're asking for help here you plan to fix it rather than pay a shop so you need some minimum basic tools. Trust me you'll use them again. Again not trying to be a Richard Head here but when diagnosing a perceived problem always check the obvious easy stuff before guessing and throwing money/parts at it. As you're learning fixing is the easy part, diagnostics is the hard part. You don't need $10,000 worth of trick Snap-on fluff, just basic tools. You'll figure it out in time keep at it.
Old 10-09-2013, 04:14 PM
7.5/10 somewhat patronizing but accurate. Mother nature decided to rain so I think it's gonna have to wait for today.
(sigh) knocking from engine... CJ the noisemaker General FSJ Discussion 19 11-14-2010 02:16 AM
I got a pinging problem..... ne715 General FSJ Tech 2 09-10-2009 11:47 PM
Am I Timing this correctly????Need Help with Pinging schnerdad General FSJ Tech 9 05-11-2007 09:38 PM
More Pinging & Spark Knock Questions Anteloper General FSJ Tech 9 12-05-2005 03:16 AM
Why pinging returned after new EGR and TFI? tito General FSJ Tech 14 03-03-2004 09:06 AM
