Old 04-15-2012, 08:42 PM
dan01ster's Avatar
dan01ster dan01ster is offline
LED 1157 Bulb Conversion - Front Parking Lamp
Has anyone installed Vision X LED HIL-1157W bulbs in front park/signal housings?
They state that it MIGHT be necessary to also install their resistor kit to help slow down the flashing rate of the signal due to less reistance of the LED's versus OE bulbs....has that been the case if anyone has done this conversion?
Thanks mates.
'82 J20, 360,TF727, NP 208, Holly Projection.'74 paint scheme
'67 Jeepster 8701,true convertible,TH400,pwr top,
Buick 225.
'91 XJ, 4.0L,auto,Selectrac,Ramsey 8000,GC upcountry susp
'98 XJ, 4.0L,auto, Selectrac, police package
Old 04-15-2012, 08:53 PM
All you need is to swap your thermal flashers with electronic flashers.
http://www.oreillyauto.com/site/c/detail/BWD0/FC536/01546.oap?year=1979&make=Jeep&model=Cherokee&vi=11 79435&ck=Search_electronic+flasher_01546_1179435_2 687&keyword=electronic+flasher&pt=01546&ppt=C0010
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
serehill serehill is offline
Gone,Never Forgotten.
Do not do the resistor kit
Go to any Parts store & get an electronic flasher & install it in the place of the old flasher done deal for you to go all led. The resistor kits are a joke. Then you can use any bulb. Did mine over 2 years ago.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 04-15-2012, 09:31 PM
dan01ster's Avatar
Thanks lads...really appreciate it.
Buick 225.
Old 04-15-2012, 10:50 PM
Tourettes's Avatar
Tourettes Tourettes is offline
x2 on the electric flasher.
I've got led bulbs in every socket except for headlights. Te ones in the dash even dim without the need for a resistor. Close to 3 years now and not a single issue.
Tourettes 1978 Wagoneer
360-727-228 - MSD 6a - TFI - MSD 8.5mm - 880CCA Diehard Plat - 31x10.5x15 - LEDs in every socket
Old 04-15-2012, 10:53 PM
ThisGuyUKnow's Avatar
does that plug into fuse panel?
'85 CJ7 Laredo- Rebuilt 360, Tuned Port Injection, T-176, D300, W/T 3.31 w/Trac Loc, 31x10.5x15 BFGs
Old 04-15-2012, 11:10 PM
Sure does.
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
Old 04-16-2012, 06:31 AM
Billygoat's Avatar
Interesting, I put LED bulbs in my front parking lamps and lost my side-marker lights - then I remembered that the side markers ground thru the parking lamp bulbs - that is why the flash together with the lights off and opposite light on.
LED's don't act as a ground like a fillement bulb does when not lit - at least not the ones I bought.
Old 04-16-2012, 07:02 AM
Yagan's Avatar
Yagan Yagan is offline
gees i love the idea of LED lighting. I can't wait to do it. Bigger fish to fry at present. One day i'll do it. Great info here
Baby Blue - 81 Cherokee S 4 dr
Twin Trans Coolers no longer in radiator flow path
Baked Copper Coated B&M Deep Trans Pan
Custom Cooler ducting and braided lines
79 American Racing Cast Alloy rims
Monroe Air, Rear Reece Hitch, Front Hidden Reece Hitch,Dual Batts, re-con’d Alt, Front Bench Seat
My rig is ubber hot, my FSJ is a chick magnet
Old 04-16-2012, 11:13 AM
put LEDS in the side marker!
Old 04-16-2012, 12:28 PM
Billygoat's Avatar
you still lose your ground, and you have to watch polarity on then, bulbs don't care with post get pos/neg - LED's do
look at the diagram on an 81
http://oljeep.com/gw/elec/81/81_FSJ_...agramPage1.jpg
the side marked are tied into the the pos on the 2 filiments of the parking lights, with no power a standard bulb becomes a resistor thru the filliment
creating a ground connection, and the side marker pos/neg feed changes dependent on which wire is feeding power to the parking light.
Just putting this out there so people can research what they need so all the lights work properly.
and X3 on the electronic flashers - they are the only way to go even with standard bulbs
Old 04-16-2012, 06:17 PM
Tourettes's Avatar
That is interesting!
Please tell me more about how your side markers are grounded "thru the parking lamp bulb"
Old 04-16-2012, 07:40 PM
None of this happened on mine I have all leds
Sounds like something isn't right.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 04-16-2012, 07:53 PM
Logans Run's Avatar
Logans Run Logans Run is offline
I bought LED side markers ... have not put them on yet ... noticed yesterday though ... that my flashers work, but my turn signals dont work
what is up with that!
The Falcon ... 73, 360, TH400, D20, D44 3.54 (F&R), 6" BJ's spring lift, 35"
"I've fought tougher men, but I really can't remember when."
P.S. those are some beeftastic bumpers!
My Build Thread:
http://www.ifsja.org/forums/vb/showthread.php?t=151753
Old 04-16-2012, 08:13 PM
dan01ster's Avatar
This is getting more interesting by the post. I'm going to hold off until the dust settles here ...This is all great stuff and definitely worth learning.
So if I replace my front signal/park bulbs AND the front side marker/signal lamps with LED's and also install the electronic flasher, I should be good to go or is this ground thing going to still be an issue?...and if so, what is the fix.
Buick 225.
Old 04-16-2012, 08:18 PM
Interesting
[quote=Logans Run]I bought LED side markers ... have not put them on yet ... noticed yesterday though ... that my flashers work, but my turn signals dont work
what is up with that![/quo
Do you have an electronic flasher?
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 04-16-2012, 08:41 PM
Logans Run's Avatar
I seriously doubt it
.. but I have not installed the LEDs yet
My Build Thread:
Old 04-16-2012, 08:49 PM
dan01ster's Avatar
serehill...what make of bulb did you install?
One of the sites had some tips about which bulbs to buy and stated that buy red for red lens and amber for amber lens etc. Something about the light frequency being blocked ie if using white bulb in red lens or white with amber lens.
The only make I've looked at so far is the Vision X and their '360' series 1156 and 1157 and 194's.
Buick 225.
Old 04-16-2012, 09:00 PM
I had read about the color issues
Believe it or not I did put amber in the front & red in the tails but I used whites in the side markers & had no issues but I really like the amber & red I used the multiple bulb units. I bought everything from these guys. After I bought the chinese junk first. I haven't lost a bulb in 2 years. Not all leds are the same.
http://www.superbrightleds.com/
I used these: Yes thery are expensive. I went the chinese route & they started burning out. Now they have lasted over 2 years & are brighter than any incadescent.
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fspecs%2F115 x-x12x19.htm#photos
Here's the diference in color. Go to this link scroll down & there is a link to selct color it will show you what the white bulb looks like.
http://www.superbrightleds.com/cgi-b...rake-turn.html
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 04-16-2012, 09:09 PM
dan01ster's Avatar
Ya that's the site I looked at last night...their pointers...
"Which Color LEDs should I use?
For best results the LED color should be the same as the lens color or if bulb is behind a clear lens, use the appropriate color for turn and brake light functions. As an example: a red lens will filter out all but the red portion of the light so if the light is all red, none or very little light will be blocked by the lens. The light from a White LED contains very little light in the red portion of the visible spectrum so most of the light would be filtered out by a red lens."
Thanks for the links serehill...more research to be done on my part....now I'm off to bed...thanks again.
Buick 225.
Rhino Conversion. Rande General FSJ Tech 15 11-24-2003 12:57 AM
front drum to disk conversion? cocco_78 General FSJ Tech 5 07-20-2003 07:37 AM
Tips on performing a sping over front D60 conversion? netbear General FSJ Tech 20 03-05-2003 02:10 PM
front coil over conversion. mulepic General FSJ Tech 5 08-19-2002 10:52 AM
Front coil conversion Sycho15 General FSJ Tech 0 07-18-2002 01:28 PM
