Old 01-25-2012, 12:54 PM
Logans Run's Avatar
Logans Run Logans Run is offline
on board compressor?
I have an old AC compressor out of a 1968 Cougar, and I was thinking about putting it in my rig for an on board compressor ... has anyone done this? how many PSI will it put out ... pros or cons?
The Falcon ... 73, 360, TH400, D20, D44 3.54 (F&R), 6" BJ's spring lift, 35"
"I've fought tougher men, but I really can't remember when."
P.S. those are some beeftastic bumpers!
My Build Thread:
http://www.ifsja.org/forums/vb/showthread.php?t=151753
Old 01-25-2012, 01:29 PM
seventynine's Avatar
seventynine seventynine is offline
What kinds of compressor is it? York?
I have done it with the stock York units they put in Jeeps. I have one on two of my CJs with AMC V8s. I plan on putting one in my J truck too.
They work great I can re-seat a bead with them on the the trail & run air tools. You need to get a pressure switch and some kind of tank. I have a custom bumper sealed on one of my CJs for a tank.
They beat the heck out of an electric pump.
Dean
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Cherokee Chief (traded for the J10)
'79 Wagoneer (RIP)
'13 FLSTN Softail Deluxe
Old 01-25-2012, 01:32 PM
1983 j10's Avatar
1983 j10 1983 j10 is offline
I've heard the sanden compressors top out at about 215 psi
1983 j10 lwb soon to be a 4.5l stroker AMC 20 rear 44 front 4spd manual in the process of restoring
01 xj 3" and 31's
Old 01-25-2012, 01:35 PM
...The only con I can think of is that you lose the abillity to run AC...if that matters to you.
I'm not sure of the volume they produce but the pressure swith cuts on at about 90psi and shuts off at about 125psi.
You can use AMC v8 mounting bracketry to mount it. Ideally you will want to run a dual pulley so if you don't have it already you would need a dual pulley for your alternator.
There is tons of info out there on how to set them up. Here is one site:
http://www.mudinyerioffroad.com/yorkOBA.htm
Dean
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Wagoneer (RIP)
Old 01-25-2012, 01:38 PM
If you use a Sanden you will have to add an oiling system to it. York compressors are oiled internally (from a crankcase resevoir)...which makes them ideal for use as an air compressor.
Dean
'79 J10
'77 Cherokee Chief
'79 CJ-7
'79 CJ-5
'46 CJ-2A
'93 ZJ Limted
'79 Wagoneer (RIP)
Old 01-25-2012, 05:30 PM
Logans Run's Avatar
Well this is what I have, and I have no idea what it is ... other than it came out of an old Cougar.
Any one know anything about this?
My Build Thread:
Old 01-25-2012, 05:33 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Looks like an old Frigidair unit, made by GM. You'd need some way to lube it, just like the Sanden. Other than that, I don't know.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 01-25-2012, 06:03 PM
Dumpy's Avatar
Dumpy Dumpy is offline
The Yorks need oiling, too, if used for onboard. Get a junkyard York for cheap and slap it on. Just make sure the pulley spins freely. I run one. I run an old compressor tank in the bed, and eventually I might add a regulator. Plenty for running air tools and filling tires.
Justin
'72 J2000 360 4bbl T18 D20
Old 01-25-2012, 06:48 PM
Lindel's Avatar
Yorks have their oiling built in. The crankcase is also an oil pan.
Sandens and Frigidairs don't have that and need a separate oiling system installed.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 01-25-2012, 09:06 PM
orangebang's Avatar
orangebang orangebang is offline
I ran the gm style on my YJ for a few years and everytime I went wheeling I would add some air tool oil to the air intake on the compressor to lube it up. Did this for a couple of years until it froze up then went to the junk yard and got another. Also put a water trap on the pressure side to get the oil out of the line and keep it out of the ARB.
1964 J 300 dana 44's 3.55's, 383 chevy 420 hp 460 tq, turbo 350, 35 all terains, and 2.5 kings.
1964 J 200 stock except previous owner put a 327 in it does not run yet.
Old 01-25-2012, 09:27 PM
Logans Run's Avatar
I really dont want a bunch of "junk" under my hood... so maybe Ill find a York ... if indeed they really dont need an oil tank to feed them.
My Build Thread:
Old 01-25-2012, 09:45 PM
68glad's Avatar
68glad 68glad is offline
I wouldn't bother trying to mount that thing up either. Find some brackets at a junkyard and a york and be done w/ it.
68 gladiator- 455/400/20 r.i.p.
78 wagoneer- 401, drw60, drw70, 203/205, 38's, oba, obw, hydroboost, dual p/s pump, bla bla bla
"If you don't stand for something, you'll fall for anything."
Old 01-25-2012, 10:31 PM
Dumpy's Avatar
Mount it vertically. There is a hole in the side to add your oil, but it doesn't need a separate oiling system. Pour some 10w/30 in it, like, a 1/4 in, and check it every few times you use it. A long zip tie works good. If you mount it horizontally, you'll love oil. I accidentally dropped mine off of my work bench and broke off one of the fittings, so I JB Puttied a little air filter on it
Justin
Old 10-16-2013, 02:36 AM
SteelPonyCowboy's Avatar
SteelPonyCowboy SteelPonyCowboy is offline
[quote=seventynine]...The only con I can think of is that you lose the abillity to run AC...if that matters to you.
NOT exactly.....................
Contact this Mark for a bracket to mount two Yorks on your FSJ. I got one for my OBA set up because in AZ you can't give up your A/C
Mark Brinson email sales@searchers4wd.com
They don't show it on their web site yet but they will fab one up for you and ship it out quick.
Old 10-16-2013, 09:59 AM
JeepWrencher JeepWrencher is offline
@ SteelPony
Where does the second York mount, in place of the air pump for the emmisions?
I'd love to see pictures of the setup as I live in FL and no AC here is miserable.
1983 J10 Short Bed
AMC 360 / 727
230,000+ miles and counting
No mods just keeping Darkhorse running
Old 10-16-2013, 10:29 AM
They mount side by side vertically. Move your factory York to the upright position, attach brackets to the left side, mount 2nd compressor upright, done. No interference with emissions or anything else.
Old 10-16-2013, 11:04 AM
goldhammer's Avatar
I did a Sanden on the XJ following the article in JP magazine from a year or so ago. They used hi-temp synthetic wheel bearing grease and really slathered up the guts. Have not had any issues with it for a little over a year now, Have an 80/110 pressure switch and around a 1 gal. tank (the mate will go in as soon as I change the muffler out, 3" sq., .188 wall x 36" under the floor welded to the frame rail reinforcements. They don't hang below the rails). Takes about 10 minutes to air up all 4 - 31's from 14 to 28 PSI and put away the hose and such. Used a hunk of garden hose for my air intake from the air cleaner to the pump and had NAPA make me a pressure line from the A/C unit to my manifold that has a gauge, outlet, inlet, pop-off (150psi), pressure switch and line to the tank/tanks. Lines to the tanks are 300 psi 3/8 air hose, all on quick disconnect fittings that are on all my air tools.
Art
ASE Master Collision Tech
Old 10-16-2013, 11:35 AM
Headhoncho's Avatar
I say just swap the entire engine from the Cougar too! Here's mine with a York compressor. Great for filling tires but haven't tried to run air tools yet. Pressure is set around 90lbs and I have a 5 gallon tank. All my fittings and intake filter came from Grainger and Lowes.
JR
1966 mustang fastback
'07 Dodge Charger 3.5
Old 10-16-2013, 12:03 PM
goldhammer's Avatar
Pressure switch, pop off and gauge came from Grainger as per the article, all the fittings and t's and crosses came from NAPA and the hose and disconnects from my Cornwell dealer when he comes every week at work.
Art
Old 10-16-2013, 11:22 PM
I just picked up another dual piston York (and a 440/727 from a motorhome) That will make my onboard air in Blackjack
headliner material 84Waggie General FSJ Discussion 23 05-13-2015 05:57 PM
If you were to convert to diesel getlost4x4 Diesel Swaps 56 08-25-2012 05:33 PM
AC compressor Problem bigblack'74 General FSJ Tech 5 06-28-2009 01:54 PM
Need a sanden compressor model number GW Fisherman General FSJ Tech 8 07-16-2007 02:55 PM
York compressor Slim Off-Road FSJ Tech 15 11-22-2004 01:25 AM
