Everyone,
I finally finished assembling my new 360 yesterday. Motor purchased from S&S Engine. I also purchased a new timing cover, oil pump, and mid-plate from Bulltear. Installed everything last night. Went to drop in the distributor and found it very difficult to align the oil pump shaft into the dizzy. I ended up pulling off the drive gear and slid the dizzy in to see if it was a tight fit. The dizzy slid right in. I then pulled the oil pump to see if it fit into the dizzy, and it fit, although it was a tight fit. In the end it looks like the timing cover is not machined correctly and the dizzy does not engage the oil pump shaft straight on. I did get the dizzy in finally engaging the oil pump but this would push the dizzy crocked and force it into a bind. It would then be very difficult to rotate the dizzy as you would to advance or retard the timing. Pulling it back out was extremely difficult as well. Any thoughts, or do I need to just get this timing cover warrantied?
FYI, I am runnning a Z&M Jeeps HEI, however I know it is good, because it ran for over 6 months smoothly in the old motor.
I wish i didn't have to pull apart a brand new engine.
Kevin.
Kevin.
