When I bought my 73 a few years ago, it came with the AC (and all associated brackets) removed, but still had the under dash unit (which works) and the condensor (which will be replaced anyway). Not having seen the alternator and AC bracketry in stock form, I'm basically starting from scratch and want to upgrade to a larger alternator when I add (re-add) AC. So, my question is more about the AC compressor brackets and what is most desirable (from a model year standpoint). I believe that different eras of FSJ's used different compressors, so what would the most desireable be, since I'm starting from zero? I know the alternator stuff has been covered quite extensively on here, so I think I am set on that (searching for brackets from a 78+, correct)?
Thanks in advance...glad to be back!
