In replacing the vacuum actuator on my 73 Wag TH400, I seem to be at a stopping point. First of all, the replacement is a much, much tighter fit to slide in (the old one goes in and out no problem, the new one not so much). Also, after removing the old one, this guy was hanging out there in the hole and I'm not sure what to do with him:
Does it simply sit loosely in the hole on the shaft of the new actuator, like this?
For comparison, here is the old one and the new one. There is no perceptible difference in the size of the two, but the new one sure doesn't fit like the old one. I haven't measured with calipers yet. And I have read that the external portion of the actuator is smaller on the replacement parts, so that doesn't bother me, just the diameter of the part that slides inside the housing.
Also, with the actuator and the above pictured piece removed, if I stick my finger in the housing, I feel what feels like a roller bearing or something cylindrical that lies perpendicular to the opening laying in the bottom. Is that normal or did something else fall out when I took the old one out?
I'll have a beer and await someone more experienced than me to chime in...thanks as always, guys and gals.
