hey gang,
Ok so here is the main question. My 79 wagoneer had at one time a roof rack on it, but it now has plugs in a majority of the correct places and some holes look filled in. The issue is the plugs and holes that are filled in are covered by a textured paint and they will not just pop out so I can't install the plugs and screws. So my question is should I either use some self tapping screws and silicone and tap into the plugs, or should I drill into the roof and use the original plugs and screws? If that is the way to go, what size are the holes?
Second question is I want to put a 76 front grill shell on my 79. The 76 is more the vertical grill look that is more the "Jeep" traditional look than the grill I have. Is this possible without any major modifications or should I just stick with what I have?
Thanks gang.
Thanks gang.
