OK, so I removed the pan and the Valve Body and found nothing that looked like metal shards, shrapnel or shavings.(that's good right?)
Then I disassembled the Valve Body looking for anything that could cause blockage or prevent normal operation of its many parts. Again I found nothing that jumped out as problem.
But as I reassembled I noticed this...
It appears to be a groove worn in by the ball traveling back and forth and is just barely noticeable on the back side. Could this be causing the slipping issue I've been troubled with?
And then there is this little guy...
Can someone tell me where in the Valve Body this piece goes? It is about 3/8" long and 1/4" diameter. I did not see where it came from, I blinked and it was sitting there. I'd like to install the Valve Body tomorrow, but not til this piece finds its way home.
