12-19-2009, 01:47 PM
Coil - How the heck does this happen???
Dan Stewart
1958 Land Rover Series 1
1991 Wrangler YJ
12-19-2009, 01:53 PM
i've had the same kind of trouble with an accel coil: the plastic base would crack and the oil would be pressurized and come out in fumes over the engine compartment.
never found what it was, only that it would run hot and do this in traffic jams or when leaving the key on the ON position.
if anyone has a clue, it could help me too :-)
12-19-2009, 01:58 PM
do you have the stock distributor? or an aftermarket?
Jeepless
In to Turbo crap now
12-19-2009, 02:00 PM
mine is accel aftermarket...
12-19-2009, 02:37 PM
Are you still using the ballast resistor? How much voltage do you have at the positve coil wire?
1990 Grand Wagoneer
Stock 360/727/229
Restoration in progress.
12-19-2009, 02:42 PM
It is the original duraspark ignition. I eliminated the resistor wire, or rather it melted itself to death. I repalce factory coil with an internal resisted coil.
Dan Stewart
1991 Wrangler YJ
12-19-2009, 03:05 PM
Did you leave the key on for a while?
79 J10 Honcho 360/T-18/D20
Summit 8600 cam, GM TBI
78 Wagoneer 360/TH400/QT
12-19-2009, 03:12 PM
I probably have a time or two, but wouldnt it be the same as if you drive it for a long time? Say leave the ignition turned out for 4 hours, the same as driving the truck for 4 hours straight?
Dan Stewart
1991 Wrangler YJ
12-19-2009, 03:19 PM
Nope. when the truck is running, the coil is being switched on and off rapidly. When the engine is not running with the key on, it is not being switched. The windings are saturated and a higher current flows so the coil heats up.
12-19-2009, 07:59 PM
t.f.i. upgrade time...
85 Grand Wag:360 *219k* 4bl 1406, tfi upgrade, rear 3" blocks,front(get this) "rear"shackle drop kit (net 5" lift) , 265.70.16 bfg at's,flomaster40,boobie grille swap
12-19-2009, 09:47 PM
for me key was left on - indeed for about 1 hour.
but it also happened when driving in heavy traffic.
the resistor wire is still there... but how effective is it???
can i add something for it not to happen.
i've got 14V on the Volt meter going up to 15 when in hight rpm.
12-20-2009, 12:53 AM
![[]V[]AXX's Avatar](customavatars/avatar22757_1.gif) |
I have had this issue with two Accel coils. One on my Jeep, and the other on a Ford van. In both cases, the coils were less than six months old, and simply cracked in the same way, the one on the van totally broke off. The heat doesn't help, but these are not well reinforced pieces we're talking about. I think that the plastic is just not up to quality and dies an untimely death. The same vehicles have worn different brands of coils for over a year without a reoccurence. I really don't think you have to look any further than the "Made In China" label.
12-20-2009, 12:45 PM
I'm going to have to eat my shoe now after my comment in your hard start post:
"Probably safe to assume your coil is good if you have spark at the plugs."
This is the reason for the Accessory mode at the ignition switch.
'77 Cherokee S: 350 SBC, TH400, BW1339 Doug Nash PT, Performer intake, Carter AFB, & Mallory HEI. Needs: love
'78 Cherokee S: 401 AMC, TH400, BW1339 w/ MM PT, Carter AFB, & BJs 4" Lift & Skyjacker Nitros. Needs: $ thrown at her
12-20-2009, 12:56 PM
Well I just pulled my engine harness and started to remove the duraspakr ignition. All wiring was fine. Now finish gappnig the spark plugs and order the HEI.
Dan Stewart
1991 Wrangler YJ
12-21-2009, 01:02 PM
BUMMER
Called Summit racing today. I got the coil 5 months ago. The petronix warranty is for 90 days on a coil. Oh well, i will put the replacmeent money into gettin the HEI.
Just remember 30 days warranty for a Petronix coil.
That is all.
Dan Stewart
1991 Wrangler YJ
Thread Tools |
Display Modes |
