07-30-2009, 03:29 PM
Rear tailgate window "clips."
Does anyone know what size the two metal clips are for the tailgate window? I found this picture online and it's the two round clips in the bottom of the picture. I finally got my window to go up and down, but the missing clips prevent the window from staying on the two rails and then the window gets stuck. I tried to get my hand in there to measure them, but I don't have fingers like E.T.
07-30-2009, 03:34 PM
BJ's Offroad has them, AFAIK. Then have an electrician friend who also owns an FSJ drill two access holes in your tailgate for you. That's what I did.
Ethan Brady
www.bigscaryjeep.com
07-30-2009, 06:33 PM
07-30-2009, 07:48 PM
There are at least a couple of good write-ups in the tech section dealing with tailgates and yes, these clips. I followed the steps there with success.
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
07-30-2009, 08:41 PM
Thanks guys. I found the tech articles etc, and I had searched BJ's but didn't look under misc. You guys rock!
07-31-2009, 03:27 AM
I eliminated those!!@@#$%%^&* clips along time ago,I simply remove the power assembly and drill & tap holes through the pegs & use bolts & washers in their place(use flat head bolts) good luck have fun!
07-31-2009, 04:01 AM
I use regular 7/16" E-clips from the hardware store. And yeah, adding those access holes helps a lot.
S.J.
"Carpe Mañana".
'83 Wagoneer
Thread Tools |
Display Modes |
