Old 05-08-2011, 09:53 PM
JP29 JP29 is offline
BJ's woodgrain trim install pics?
Hey everyone just getting around to install the bj's woodgrain kit. For the sake of being cautious I was wondering if anyone had pictures of the trim installed (specifically near the front and rear fenders where the little pieces of trim go) The kit came without directions so I wanted to make sure I was matching everything up correctly. Help would be appreciated!
Thanks!
Old 05-09-2011, 12:52 PM
TPICherokee's Avatar
It should have come with instructions. I have some one here in a PDF file.
I just shot you off an email via this forum (which won't allow attachments), just respond to it and I'll get you some instructions.
Old 05-09-2011, 01:16 PM
Tripwire's Avatar
Tripwire Tripwire is offline
Id like a peek at the instructions as well please
Abort? Retry? Ignore? >
Old 05-09-2011, 07:55 PM
ajminla ajminla is offline
Can you post pics of installed trim?
Have to do 2 GW's for trim and moulding.
Not sure yet what to buy.
'89 Grand Wagoneer
Black with Sand Interior
"The Other Woman"
Old 05-09-2011, 09:50 PM
Thanks
Thanks TPICherokee!
Old 05-10-2011, 06:37 AM
Mex in the city's Avatar
Mex in the city Mex in the city is offline
I did install the kit. Look at my post. Need more pics or tips? Let me know.
http://www.ifsja.org/forums/vb/showthread.php?t=119864
83 Wagoneer. Front: 35 spline D60, Coil spring conversion, E-Locker. Rear: Sterling 10.5, Shackle flip, Detroit. Gear ratio 5.38:1. 39.5 Interco Irok's, HEI, hydroboost, hydroassist, bob job, sliders, roll cage, 12K winch. Runs on propane!!!
87 GW, 3", 4.10, 32" BFG AT, K8600, 2131, 1406, HEI, hydroboost.
71 Datsun 240Z turbo.
Old 05-10-2011, 07:52 AM
Tripwire's Avatar
Yes can you provide some detailed pics of the install and a step by step write up? . Im sure it will be very valuable to all of us
Trip
Windshield trim install..... Gutter General FSJ Tech 4 01-07-2010 07:38 PM
woodgrain trim curling fix? jamsni General FSJ Tech 5 03-11-2008 10:41 PM
chrome trim around woodgrain 76phoenix General FSJ Tech 0 04-14-2006 03:57 PM
grand wag woodgrain trim removal and instalation sandmanb General FSJ Tech 5 09-12-2002 03:18 AM
How do you bend/glue woodgrain trim Bryan General FSJ Tech 1 12-11-2001 12:39 AM
