(TOM)hydroboost
  • slewfoot
    • Oct 02, 2002
    • 312
    (TOM)hydroboost
    now i have a CJ-5 with manual brakes could the hydroboost be fitted to work this? im running 33 12.50 15's so with manual brakes it can get hairy trying to stop fast
    [ March 31, 2003, 03:40 PM: Message edited by: PC ]
    from the flames of hell to the gates of glory God Bless them all
  • Retro93
    Junk Collector
    • Nov 02, 2001
    • 2850
    Yes.
    • slewfoot
      • Oct 02, 2002
      • 312
      heck all I have is manual brakes now but I do have a hydro boost system in the back of my truck what all do I need to do to convert it?
      • greasyjeep
        • Oct 01, 2002
        • 490
        Two good write-ups
        Josh<br /><br />1983 Cherokee Laredo <br />2000 TJ <br /><a href=\"http://www.simbur.com\" target=\"_blank\">http://www.simbur.com</a>
        • Retro93
          Junk Collector
          • Nov 02, 2001
          • 2850
          You might want to switch to disc brakes in the front. No surprises then.
          • slewfoot
            • Oct 02, 2002
            • 312
            already have disc on the front
            • Joe J-Truck
              • Oct 05, 2001
              • 1623
              How does this work with all drums?
              RB must have a case of yellow paint! Hahahaha
              • slewfoot
                • Oct 02, 2002
                • 312
                whoaaaaaaaaaaaaaaa I said whoaaaaaa and good god it stops now stands my little CJ right up on her nose definatly gonna take some getting used to but thanks
                • #9
                  Just got another case, Joe....
                  Todd
                  www.ttsfabworks.com
                  • loyd
                    • Mar 16, 2002
                    • 274
                    are these boosters only on 77-78 cads or are they avalible on newer cads? how do you test to tell if they are good or not before installing?
                    • #11
                      After 78 the boosters are vac....
                      No real way of testing, I had installed mine and leaked like a siv! It slowed down alot after a month, but wound up using it as a core and got a new one.
                      Todd
                      www.ttsfabworks.com
                      • Retro93
                        Junk Collector
                        • Nov 02, 2001
                        • 2850
                        True Todd...there is no way of testing a unit short of installing it to see if it leaks. No big deal. If it does, the core value far exceeds what you will pay for it at the bone yard.
                        • Sitting Bull
                          360 AMC
                          • Sep 18, 2000
                          • 3471
                          Just moving topic...
                          • 4DWUDS
                            • Feb 01, 2003
                            • 209
                            FYI.. My 1994 and my 1984 Chevy 1 ton box vans(Work trucks) both have the hydroboost system on them.
                            <a href=\"http://members.cox.net/4dwuds\" target=\"_blank\">4DWUDS</a><br />To err is Human<br />To forgive Divine<br />Neither of which is<br />Marine Corp Policy<br />1983 Wagoneer. Purchased 1984 <br />1983 Parts Wagon<br />1981 Draggin Waggin<br />360 with Edelbrock & 625 cfm Carb<br />MSD6 with TFI upgrade<br />8000# winch for my F*^D friends
                            • wrinkledmeat
                              • Sep 06, 2002
                              • 1474
                              Is $45 too much for the hydroboost setup? They refuse to just sell me the hydroboost and insist I take the entire brake system from stem to stern.
                              \'Life is not measured by the breaths we take, but by the<br />moments that take our breath.\'<br /><br />84 GW \'Woodstock\'<br />360/727<br />31\" meats<br />Emissions Delete <br />2 1/2\" exhaust<br />Flowmaster 40 series (LOUD)<br />Tadrack <br />Factory Brushguard <br />Hella Lamps<br />Sounds by Sony (almost louder than the exhaust)
