While looking at the engine compartment today I noticed a vacuum line that looked loose on the charcoal canister. It ran up to the carb and has a valve about midway in between the canister and the carb. The valve/sensor or what ever it is has wires coming out the back of it. Anyway the line looked a bit loose where it attached to the charcoal can so I pulled it loose(it didn't take much effort to pull it off). I looked inside the line to find something orange and threaded. I knew right away what it was and decided to remove it. It was about 1.5 inches from the end of the line and wedged in tight as bark on a tree.
Ended up having to cut the line up past the wire nut. I reinstalled the line to the canister and started the engine. It seemed to run as good as it did with the wire nut in the line.
My question is what if any adverse effect would that line being plugged have on the engine, carb, price of tea in Moab, quantum physics, who shot JR? What is the device inline between the canister and the carb? The vac line hooks to the far right connection on the canister viewed from the front of the Jeep.
Nothing like chasing down PO's reasons for doing what they did to your Jeep
