Old 07-29-2004, 03:48 AM
Robber80's Avatar
Robber80 Robber80 is offline
what backspacing with a ford d60 in front. 39.5" Iroks?? 3.5"?? or 4.5" or what?
*Sold to move* off the frame tube buggy, front 35spline HPd60, rear 35 spline D60. Np203/205 doubled with 3.2 to 1 gear in the 203. TBI 350/th400. Full hydro. and 44s. come get some.
Old 07-29-2004, 05:31 AM
rockjeep44's Avatar
The Advisor
3.5 is what'd I'd run
Buggy Buildup
Originally Posted by welchct
Old 07-29-2004, 07:48 AM
blt2krl's Avatar
blt2krl blt2krl is offline
3.5 is what I run but that is on a chevy dana 60
Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
Robber80's Avatar
do you have an idea of what track width i'd have tith the 13.5 inch wide iroks and 3.5" backspacing. i think all ford front d60 might be the same width, like 69" i think.
Old 07-29-2004, 07:50 AM
blt2krl's Avatar
I think it is like 80-82 inches form outside edge to outside edge? I would have to measure it agian to tell you for sure.
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
Old 07-29-2004, 08:19 AM
FullsizeWagon FullsizeWagon is offline
8" rim?
If axle is 69" wms to wms, ~84-85"
[ July 29, 2004, 02:20 PM: Message edited by: FullsizeWagon ]
Old 07-29-2004, 08:20 AM
dnixon dnixon is offline
I'd judge it on what kind of trails you are going to be going on.. if they are tight I would probably run the 4.5" if you have a lot of room to roam then I might go 3.5"
Or if you are like me and running a 15" rim you would go with 2.75" uber wide... [img]smile.gif[/img]
All It Takes Is Money.
I'm the reason why you can only have Jeeps for Avatars. You're welcome.
Old 07-29-2004, 09:02 AM
blt2krl's Avatar
Okay rob I measured it and it is 87" My 39.5 are on a 16x10 rim.
[ July 29, 2004, 03:04 PM: Message edited by: blt2krl ]
Paul Hartman
79 waggoneer
WWW.PLANET4X4.NET
Old 07-29-2004, 09:20 AM
viscacha's Avatar
viscacha viscacha is offline
Cool
Check out the clearance issue with the frd dana 60 dual piston caliper. The lower bolt that holds it together is 1/8” out and 1/8” in from the inside diameter of my 16”x 8” wheel with 4 ½” back spacing. That’s a little too close for me. I am thinking about 17” wheels with 4 ½” bs.
steve
’86 J20
SOA, Dana 60's, F/R Lockers
Full High Steer, Ram Assist
Bunch of Other Stuff
Old 07-29-2004, 10:21 AM
robselina robselina is offline
what size rim? 16 or 17? If 17s, I'd go max you can, 4.5+ to keep the width down and improved turning radius.
Rob
Old 07-29-2004, 10:51 AM
Robber80's Avatar
hmm, ok guys so i want to run a 17 but i also want it to be a hair wide so i have a good center of gravity. so i'm thinking 3.5". also just for the time being, i want to tool from my shop to my house to use my welder, can i put my 38.5x14.50R15 on a set of 15x8 really offset rims i have laying around. they clear the calipers, but i just want to put the tire on to drive less than a mile to my house. i know its a wid e tire for a 8" rim. but am i really going to die from it?
Old 07-29-2004, 11:17 AM
Will Morris Will Morris is offline
You should be fine if the wheels clear the calipers. That's the biggest issue. As far as mounting a 14.5" tire on an 8" rim, you should be fine, it'll pinch the tires some, but with 38.5s you have so much sidewall you won't really notice it all that much. I'd say your bigger safety concern is going to be tooling around with no roof and cage until I get up there. By the way, I'll give you a call and let you know my detailed schedule in a couple days.
Will
'78 Cherokee NT in GA
'79 J10 Golden Eagle in UT
