I have a '79 golden eagle that I am going to buy a winch for. I am on the bubble between a warn vr10000 and a vr12000. If anyone has knowledgable/experienced input I would appreciate it.
Thanks,
Jay-ten
10k will be more than adequate. I have a 10k smittybilt & 6k lb wag. Have not found myself wishing for a 12k yet. A golden eagle isn't even close to 6k lbs.
68 gladiator- 455/400/20 r.i.p.
78 wagoneer- 401, drw60, drw70, 203/205, 38's, oba, obw, hydroboost, dual p/s pump, bla bla bla
10k will be plenty big. General rule is 1.5 x GVWR, Both my J-4000's had older 8000 lb Warn-Belview stand up winches and always got me and others unstuck. I've never needed more than an 8000 on anything up to 3/4 ton trucks.. Bigger is better but only to a point. Whatever route you go DO buy and use a snatch block.
10K will probably be ok. A jeep could use more than twice it's weight in pulling power to pull it out of the mud. You're not pulling a free wheeling machine. There's really not that much difference between the 2 winches. Although you can get a way with the 10 a few pennies more resolves your question. Remember the saying I coulda had a V/8.
I have a 12K. I have loaded it up completely. The snatch block is always an option as Joe said. It's a great option. This is a huge investment. My winch has done everything from pull fence post, tree trunks, & roots, straightened car frames raised radio towers, to pulling dead vehicles on the trailers & pulling vehicles out of the mud. I even raised the front end off the ground to untangle some barbed wire in the middle of nowhere. It's not a place to cut corners.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Your power supply for the winch is another thing to look at.
A dual battery set up is best for a winch.
Tip of the iceburg batteries alternator wiring all need to be upgraded.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
A good rule of thumb is your winch should be at least 1.5 times the weight of your Wrangler. If your Jeep is stock other than the winch you will be adding, you can just multiply your gross vehicle weight (GVW) by 1.5. I will suggest you to take help from online portals as it will provide lots of options. I was also in a dilemma a couple of months back when I have decided to buy a new winch for my Wrangler and got some decent options to consider on portals like Quadratec, Jautostation(https://jautostation.com/best-jeep-winch/), Ford jeeps, Jeep world websites.
Wow What a can of worms. A snatch is used to double your pulling power. Why well 10k 12k is off the last row of cable. As you bring your cable in each layer of cable decreases your pull weight. So a 12k winch your first layer of cable only has 6800 of pull power. This is a rough number not exact. Then you snatch block it means more cable out so now your in 3rd row.Now you pull at 9200.
Like what was said battery alternator wiring. Another worm can.Amps are current flow. So a free wheeling winch draws 65 amps. At max load it can be as high as 400 amps. So to do it right bigger wires to carry the load ,alternator to make amps,battery to stow the amps. This is a rough ideal what needs to be done right.
Owner of Jakes FSJ Junkyard 91 Jeep Cherokee /2006 3500 Dodge AKA Babe the big blue puller
Hire the handicapped, they are fun watch!
Always funny when someone bumps an old thread just to repeat a previous answer.
And without an acknowledgement of the repeat. Bad form.
Sic friatur crustulum
[QUOTE=Jack105479]A good rule of thumb is your winch should be at least 1.5 times the weight of your Wrangler. If your Jeep is stock other than the winch you will be adding, you can just multiply your gross vehicle weight (GVW) by 1.5. I will suggest you to take help from online portals as it will provide lots of options. I was also in a dilemma a couple of months back when I have decided to buy a new winch for my Wrangler and got some decent options to consider on portals like Indiamart, Jautostation(https://jautostation.com/best-jeep-winch/), extremeterrain.
