Is there a Cheap (like <$100) option to get 1.7 ratio rocker arms?
  • rang-a-stang
    • Oct 31, 2016
    • 5509
    Looking around on IFSJA I see the only easy/reliable 1.7 rocker arms for our AMC V8s seem to be Harland Sharp and Scorpion. Both are over $300 on Summit racing. I plan on removing my valve covers to paint them and install new gaskets when I do my intake and thought that might be a good time to do some 1.7 rockers (if they are cheap enough). I see posts here and there that talk about using Chevy or Ford rockers and the pros and cons of those but they are mostly talking about roller tips. I don't really care about roller tips but thought a little extra lift would help (especially with my new intake being installed).
    Its not worth $300 for me to install them on a stock cam in an engine that never sees 5k RPM but if I could find some cheapie, bolt on steel rockers, I'd be game to try those...
    Chuck McTruck 71 J4000
    (Chuck McTruck Build Thread)
    00 Baby Cherokee
  • wiley-moeracing
    • Feb 15, 2010
    • 1430
    save yourself some money and don't buy rockers and use what have. there is no advantage to upgrading rockers if nothing else is done.
    • 72jeeperjoe
      • Nov 08, 2016
      • 168
      I would say stick with the factory ones unless you plan on building the engine up. Factory rockers are usually stronger than aftermarket unless you go high end. If you upgrade up to 1.7 rockers you will gain a little lift but you wouldn?t really notice too much in my experience.
      1983 Jeep Wagoneer-322,000 miles.
      1972 Jeep Wagoneer-360-auto-sold
      1988 Jeep Grand Wagoneer-One owner-64,000 original miles-Sold unfortunately
      1968 Jeep Gladiator, full Resto in progress
      1963 two door ifs one owner Wagoneer
      • rang-a-stang
        • Oct 31, 2016
        • 5509
        copy all. Thanks, gentlemen. Stockers it is.
        00 Baby Cherokee
        • fsj454
          Long time member
          • Jan 02, 2015
          • 521
          Roller tips
          I have 1.7 roller tips on 1982 Cherokee chevy motor and I hate them noisy noisy noisy.
          1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
