I finally finished with the major stuff. As yopu can tell, it's very dirty. Haven't ever washed it! The body is in great shape. Just some orange surface rust sopts. I plan on a paint job soon. I only paid $500 when i found it. I probably have about $6000 into it now. But some of that is like buy a set of 35's, then selling them for half price to get 36's. Then selling them and getting 38's. I did that kinda stuff abunch. Did the 258-360 swap, axle swap, T18, and tons of little thing. You know a hundred here and ahundred there, it really added up fast. Anyway, here is the link. If you click on the pic, you should be able to blow it up and read some technical stuff about what I did. Any more questions, feel free to ask. Dennis
Finally, some PICS of the J10. 14FF and ram assist.
Looks pretty good man!!! I hope your ram mounting to your diff cover holds up. Losing your steering and all your axle fluid at the same time couldn't be a good thing!
[ March 12, 2003, 08:42 AM: Message edited by: Hump ]1971 J-4800 Dauntless 350/t18/d20/D44/D60
'98 & '01 XJ both with 3" Skyjacker and BFG KOs
'90 MJ SWB 2wd getting 4wd conversion (maybe a Buick 350!)
'99 & '00 XJ parts Jeeps
Looking good!Paul Hartman
79 waggoneer
AMC360/TH-400/203/205
www.cbioffroadfab.com
WWW.PLANET4X4.NET
Wow, looks tough.
Good work.Marc<br /><b>343 W6</b> <br /><br />You can\'t be a real country unless you have a beer and an airline-it helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. -- Frank Zappa<br /><br />You\'re a feminist? aww isn\'t that cute........
Great job! Feels good to bring a J truck back from the dead even though a lot of $$ is spent. Ask me, I know.Patrick V.
MEMBER #14
78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT RIP
Looks good, but a couple things from the pics that spring to mind:
* Any way of securing the clevis-pin end of the ram with more than that external spring-clip?!? I would think a cotter pin and washer would be in order.
* Is it going to be a b*tch to bleed those rear lines, with the bleeder screw below the level of the hard-lines? Also looks like it might get knocked-off if you play on the rocks. I would think clocking it up another 90º would be ideal.1987 J-20
Video projects for my J-20 on Youtube
Well, I plan on moving the calipers up, just behind the axle tube. And as far as the diff cover, the ram only runs as much pressure as the pump can do, so I think it's not enough to rip it off. Put some serious weld on there. Did some serious turning yesterday, and no problems. I did not have any problems bleeding the lines. DennisStarting to miss the addiction!
Plus I welded the bracket toward the top of the diff cover, figure it's stronger by the bend and bolts, then say right in the middle. Now time to tear the engine down and rebuild it. Ive been driving an AMC V7 for some time now. Seems I have a burnt valve, that is stuck open.?
[ March 12, 2003, 04:00 PM: Message edited by: KYJ10 ]Starting to miss the addiction!
It looks like the 14ff worked great. Were you able to get the perches out to 50" on center?* 1981 stepside, 360, 727, 208, almost stock daily driver.
