Old 11-07-2019, 03:52 PM
mgmann mgmann is offline
Taigate - door locks - fusible link question
Recently had some work done on my 88GW. When I got it back the rear window wouldn't work using the key and the door locks don't work. The rear window works from the dash.
I know that those 2 items are on the same circuit and are controlled by a 30 amp breaker. I checked the breaker using an ohm meter and it seems fine.
Some posts have mentioned a fusible link that comes before the breaker. Where is that link located and how can I identify it?
Thanks..........
Old 11-07-2019, 08:01 PM
I would look to the driver panel switches and door lock actuators for corrosion and the tailgate key switch in the tailgate for corrosion.
What did they do?
Old 11-07-2019, 10:35 PM
What they did
Had the rig painted, new vinyl, etc. I couldn't get the rail off of the tailgate window so bought a new rail and took it to a glass place to have it installed along with a new windshield. It was all working fine when I took it to them. I get the feeling that they shorted something out when they put in the tailgate window. I had replaced the tailgate key switch a few years ago and made sure nothing was shorting out inside the tailgate, so who know what they did to mess it up.
I'm not getting any voltage reading at the breaker which is why I'm thinking that a fusible link may have gone out although that doesn't make much sense either since the breaker seems ok.
Guess I'll take the window out and see what I can find. What a pain in the butt.
Old 11-08-2019, 12:14 PM
I would say its good if your getting power to it from the front switch.Id ask the installer to fix it if they caused it if possible.
I wouldnt think its a fused link.
If your good enough to take apart the switches at the door and the front switch, and clean them I bet things will work better. Take them apart inside a box or something so you don’t lose any small parts or springs.
Check the passenger side door lock switch to see if it works. Might provide a clue.
GL!
Old 11-12-2019, 11:31 AM
cherokee83 cherokee83 is offline
Thanks..........
1st. does tailgate motor work 2nd. look between tailgate and body, make sure tailgate wire harness isn't pinched or broken wires fro tailgate harness 3rd. motor plugged up, something isn't plugged up
Old 11-12-2019, 11:48 AM
The '88 diagram shows 4 fusible links: http://oljeep.com/gw/elec/88/88_FSJ_WiringDiagramPage1.jpg
They are all right at the starter solenoid.
I would find the tailgate relay on these sheets http://oljeep.com/gw/elec/GW_wiring.html and follow it backwards to see if it's powered by one of the fusible links. Likely. Fusible links go open when shorted, and the insulation sometimes stays in place. Test for continuity with your multimeter.
fusible link vs. alternator vs. WTF? Rob z General FSJ Tech 13 01-16-2006 12:49 PM
Fusible link/Power seats/power locks chrism General FSJ Tech 1 03-14-2005 07:12 AM
Fusible Link JAllenWAG General FSJ Tech 4 06-05-2003 07:21 AM
Drag link adjusting sleeve question Galactic_Battle_Cruiser General FSJ Tech 3 11-25-2002 03:36 AM
Fusible link on starter regulator Coley General FSJ Tech 6 01-11-2001 05:06 PM
