Old 07-30-2019, 08:14 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
1976 j10 wiper control knob removal
no surprise ! I don't know how to remove the wiper control knob from dash !
HELP NEEDED
dave in NC
Old 07-31-2019, 08:01 AM
SOLSAKS's Avatar
bump
anyone have any advice ?
dave in NC
Old 07-31-2019, 10:30 AM
There is a spring washer on the knob that grabs the shaft. Flatten the bend in the washer toward the knob and it will slide off.
Old 07-31-2019, 06:30 PM
SOLSAKS's Avatar
thank you tgreese.
...wish I knew all the stuff you know about FSJ's.....
....or at least half.
again
thanx man.
dave in NC
Old 08-02-2019, 08:44 AM
SOLSAKS's Avatar
got the knob off
now can't get the chrome ring and the electronic switch out.
tried the method I used on headlight switch
which is to use a flat blade screwdriver
inserted into one of the gaps in the threaded ring
and tap with hammer
but it will not budge
what is the correct way to remove wiper switch after knob is removed ?
HELP !
dave in NC
Old 08-04-2019, 08:37 PM
Working off memory here (which may not be that great!), but I think I either gripped the outside and turned and ruined the finish, or stuck a tiny flathead in the thing inside the chrome ring and turned to loosen. Now you got the knob off you should be able to see what's what (provided it's similar to an '84).
Good luck Dave!
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Old 08-05-2019, 09:08 AM
SOLSAKS's Avatar
thanx johnson
I will need luck !
dave in NC
Old 08-05-2019, 04:20 PM
chubbinius's Avatar
Not sure, but check to see if it's like the dash mounted ignition switch...(on the ignition switch you push it towards the dash from behind to compress the spring on front and rotate it to disengage the bezel). Good luck.
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 08-06-2019, 08:24 AM
SOLSAKS's Avatar
thanx for the tip chubbinius !
dave in NC
Old 08-13-2019, 11:58 AM
HELP !
dave in NC
I have an original quote I use in the shop "If you got the job done, no one was injured, and you didn't break anything (or in this case scratch) that you did it the "correct" way.
I once made a spanner to remove a stubborn bezel nut. I made it from 1/8" flat steel. I drilled a hole about 3/4" diameter then two small holes 180 degrees apart. The small holes were threaded for screws to be inserted. The protruding ends of the screws were filed down to fit into the slots in the bezel nut.
Resistance is not futile yet.
1976 J10 seat upholstery wristpin General FSJ Tech 9 09-07-2017 06:56 PM
1976 J10 Levi Edition Trentofarm Introduce Yourself. 1 09-06-2017 08:59 PM
Cruise Control Delete / Removal jpsterluvr General FSJ Tech 5 11-14-2016 10:04 AM
1976 J10 Vapor canister help Honchov8 General FSJ Tech 0 03-21-2016 03:24 PM
