Old 04-25-2014, 04:13 AM
FSJ-Earl's Avatar
FSJ-Earl FSJ-Earl is offline
BOLT PATTERN - 71 - J2000
I just picked up a 71 J2000 and in order to get it loaded on my trailer, I need to drag it out of a field and it has two tires that are so beyond shot they will not even come close to holding air even for 3 minutes. What bolt pattern are these wheels so I can see if I can find something that fits so I can get this thing on my trailer. Thanks in advance!
FSJ-Earl
Old 04-25-2014, 05:25 AM
Are there actually holes that you can stick your finger in? If not you might try pumping them up. I have pulled many old trucks from long term resting places and found the tires will still hold air, if just for a few minutes.
One problem that sometimes occures is weeds, dirt or other foregin material interferes with the bead seal. As the tire sets flat for years the rim settles in the ground and material gets pinched in the bead area as it is inflated. try jacking it up and clearing it out before airing up.
Resistance is not futile yet.
Old 04-25-2014, 05:47 AM
FSJ-Earl's Avatar
Not my first rodeo pulling an old Jeep out of a field. The beads are broken and there are large slices in the tires........they do not hold air at all.
FSJ-Earl
Old 04-25-2014, 06:23 AM
Tornado230's Avatar
Any Jeep rim will fit (5 Lug). Nothing from the newer Jeeps, they are 5 on 4 1/2 , I think.
Bolt pattern is 5 on 5 1/2.
Ford truck rim will fit on the back, as the center diameter is too small
to fit over the hub in the front.
Old 04-25-2014, 07:38 AM
X2
Old 04-25-2014, 12:53 PM
IH used the same pattern too.
Old 04-25-2014, 01:34 PM
serehill serehill is offline
Gone,Never Forgotten.
yup
international early ford truck & jeep 5.5 on 5
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 04-25-2014, 06:15 PM
Mikel's Avatar
Mikel Mikel is offline
You can't roll it on flat tires?
1969 M715 6x6
1963 J300 Swivel frame
Old 04-26-2014, 08:18 AM
Tornado230's Avatar
Another issue that may crop up--
Depending on how long it has been standing, the brake shoes may be rusted
to the drums, making movement difficult, at best.
Tires with air in them will not solve this problem.
Old 04-26-2014, 04:03 PM
That's when you get the solid steel sledge hammer and hit the rim while it's on the truck, right around where the hubcap attaches. Mine weighs about 50 lbs so it's on my for sale pile since I broke my shoulder. I used it for traactor split rims. Even the handle is steel!
GM bolt pattern fit? MajBob General FSJ Tech 5 11-05-2008 09:00 AM
Brake Booster Firewall Bolt Pattern back2spool General FSJ Tech 5 10-07-2008 09:28 PM
Cummins bolt pattern. Heavy_Metal_Thunder_81 General FSJ Discussion 3 05-14-2008 04:10 PM
Bolt pattern Dana60FF Jeep J20 1978 J20tommy General FSJ Tech 4 03-19-2008 01:01 PM
What is my bolt pattern? danheit General FSJ Tech 1 03-01-2007 08:37 AM
