Old 02-28-2013, 09:24 AM
MrBoZiffer MrBoZiffer is offline
heat for seatbelt torx
After I stripped the head with a T50, I finally started reading about these torx bolts, and now I know how much of a PITA they are. I see a lot of ya'll are suggesting heat from underneath. What's a good/safe heat source to use?
I've got a large soldering iron that might work.
1988 GW
Old 02-28-2013, 09:27 AM
leadsled01 leadsled01 is offline
Torch's..Soldering iron won't do squat.
Old 02-28-2013, 11:03 AM
Well, ratfarts... that's what I'd thought ya'll tell me. Thanks.
1988 GW
Old 02-28-2013, 01:52 PM
serehill serehill is offline
Gone,Never Forgotten.
The torx is a weird size it you get the right one it works better
I can't recall which size it is but one of the standards seem to work but it is too small. The correct torx will eliminate your need for heat.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 02-28-2013, 01:54 PM
jeeper54's Avatar
jeeper54 jeeper54 is offline
Don't remember if they are the same but I've used a 6 inch pipe wrench after soaking with penetrating oil when I had 1 strip out. Worth a try?
Currently without
Formerly
1986 G.W. 360
1986 Eagle Wag
1985 G.W. 360
1984 Eagle Wag
1981 Wag 360
1978 Wag 401
1981 Cherk W/T 258
1966 Wag Super 327
Not counying XJs'.
[Did have a 94 & more recently a '97 GC with 5.2. for awhile. Just not the same! Now have the FSJ blues!
Old 02-28-2013, 02:05 PM
I vote for fire(flame) forget elect soldering iron or gun. You need 'hot' to breakdown the chemical bond of the thread locker goop on belt anchors. Same scenario with exterior mirror head mounting bolts. Without fire I just break the brittle torx bits.
Old 02-28-2013, 02:34 PM
goldhammer's Avatar
I just weld a 1/2 inch nut to the top of the torx head and they back right out. The heat from welding breaks them loose, but a good shot of PB after you weld the nut on wouldn't hurt.
Use some never seize on the new ones if you ever think you might need to take them out again.
Art
ASE Master Collision Tech
Old 02-28-2013, 04:46 PM
csuengr's Avatar
csuengr csuengr is offline
correct size is a T-47. Look up an impact driver (not impact wrench). It is a tool that you hit with a hammer and loosens the bolts.
If at first you don't succeed, use a bigger hammer.
Old 02-28-2013, 04:48 PM
csuengr's Avatar
Like this.
http://m.summitracing.com/parts/shc-947641
Old 02-28-2013, 04:49 PM
goldhammer's Avatar
Actually a T-50. Never ran across a 47, 45 and 50, yes, 27 yes.
Art
Old 02-28-2013, 07:24 PM
Yeah, I tried a Kobalt T50 and it didn't work, but the bit has held together. It's technically the right size, but I think the teeth are too thin so it doesn't grip tight enough. Maybe the 47 has thicker teeth?
Anyway, I stripped some of the torx head, so now I have little room for error before I have to drill it out. I'll definitely try a torch, impact driver, and PB first.
Thanks.
1988 GW
Old 02-28-2013, 07:38 PM
ProTouring442's Avatar
It's a T-47, trust me... I used to sell mechanic's tools for a living.
Here's a Snap On T-41 on EvilBay
http://www.ebay.com/itm/3-8-DRIVE-T4...8f8523&vxp=mtr
Old 02-28-2013, 07:47 PM
csuengr's Avatar
I get mine at ACE. The T-47 has thicker 'teeth" just for the stupid seat belt bolts.
Old 02-28-2013, 08:01 PM
Indeed, made for the higher torque rating of the seat belt bolts.
Lovland, CO, eh? Bought my was-a-beautiful-car-but-now-might-be-totaled M5 in Loveland.
Old 02-28-2013, 08:32 PM
J20 project's Avatar
+2 on the impact driver w/ the proper bit.
J20
BP Drivetrain...........
775-537-7918
Old 02-28-2013, 09:28 PM
Dirtfarmer's Avatar
Dirtfarmer Dirtfarmer is offline
Location: Nebraska, Scenery's not great, but the weathers bad.
If it is loctite'd in you will need heat to release it
"The trouble with quotes on the Internet is that you can never know if they are genuine." --Abraham Lincoln
Old 03-01-2013, 08:42 AM
FSJ-Earl's Avatar
FSJ-Earl FSJ-Earl is offline
Drilling these are a PITA as they are hardened bolts. Angle grinder to make to flat spots in the sides and then use a BIG pipe or adjustable wrench to get them off. The heat from grining helps break the bond of corrosion and the factory lock tight. Anyway that you do these, they are NOT fun.
FSJ-Earl
Old 03-01-2013, 09:07 AM
yeah you can't drill them
T 47 is the correct one. I took a grinder to some my son jacked on his mustang doing the same thing. I flattened a hexagonal configuration & used a socket & breaker bar to remove they are very tight regardless of heat.
I've actually been able to use a T47 after one was stripped to get it out unless it was mangled.
I've also flattened 2 side & used a 36 inch pipe wrench. Bunches have used the wrong size including me. The right quality socket & a breaker bar is the facto way to remove. You can put tons of pressure on them. I never had any luck with the Hammer impact tools. An electric impact may work but I have always used a breaker bar & T 47. 1/2" drive No Harbor freight stuff.
I've broken sockets & stripped bolts learning the hard way.
The bolts are hardened so drilling is going to destroy some bits & still get you in worse trouble. It will remove the only hope you have in getting it out when you drill off the head. Don't drill the heads off this is an absolute last resort. This will just make them harder to get out.
Edit
I didn't see FSJ-EARLS post I agree but use a pipe wrench cresent is a waste.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 03-02-2013, 03:38 PM
grandjeeper grandjeeper is offline
Originally Posted by serehill
The bolts are hardened so drill is going to destroy some bits & still get you in worse trouble. it will remove the only hope you have in getting it out when you drill off the head. Don't drill the heads off this is an absolute last resort. this will just make them harder to get out.
A carbide bit will make short work of drilling through the bolts (if you need to).
I had had all else fail, and finally drilled it out and Heli-Coiled it back to 7/16-20.
Old 03-02-2013, 07:35 PM
csuengr's Avatar
I was lucky. The ones in my 77' Cherokee came right out using just a 3/8" ratchet.
No Heat shaggywaggy88 General FSJ Tech 12 11-04-2011 11:21 AM
88 Grand Wagoneer hard to start/stalls in heat gareth General FSJ Tech 14 10-19-2010 10:28 AM
Evil torx, new seat belts shimniok General FSJ Tech 8 10-09-2007 08:20 AM
probably not the last word on cooling.... brent General FSJ Tech 38 07-18-2003 08:29 AM
Help please Dan G General FSJ Tech 36 09-02-2002 08:47 AM
