Old 10-08-2019, 09:16 PM
Sgtjoyce Sgtjoyce is offline
Just dropped the tank to replace the rubber sections of fuel line and heard some "stuff" sliding around inside as I lowered it. Opened it up to find lots of rust/junk inside. I heard gas tanks don't usually rust, not sure what happened to mine. The float rusted completely through. Any ideas?
20191008_154229 by John Joyce, on Flickr
20191008_154345 by John Joyce, on Flickr
Old 10-09-2019, 05:58 AM
That's an older(79-earlier) metal tank.
OP has a later model with a poly tank.
Call around and find a shop that cleans gas tanks.
$50 took care of nasty tank in my dad's '79 Cherokee.
Or search online lots of methods for diy clean out of tanks.
That is a LOT of rust so before spending any money make sure it's worth saving.
Old 10-09-2019, 06:48 AM
I think I'll just get a poly tank. I'm more curious how it would get so rusted. Could it be a filler/vent line leaking rain into the tank? Or is that not really possible? It had a locking gas cap (no key) and it doesn't come off but it doesn't fit tight either. Not sure how long it has been sitting bone dry. I assume some gas in the tank would have helped keep the rust from starting.
Old 10-09-2019, 08:14 AM
got that way from sitting for a long time with it being empty or partially filled.
If it was less than a full tank moisture will form repeatedly allowing rust to take hold.
Filling the tank is part of vehicle storage 101.
Old 10-09-2019, 09:16 AM
+1
Condensation forms inside the tank. More of a problem in the humid parts of the country than the desert. I grew up in MI and it was a general rule adults hammered into me to prevent carb/fuel line freeze up. Never run your tank below 1/4 full in winter and preferably fill when down to 1/2. Less exposed sheet metal the less condensation. Regularly using a gasoline fuel system drier like HEET was also SOP.
Old 10-09-2019, 01:16 PM
'89_Wagon '89_Wagon is offline
I have a used one if you're interested. Came out of an '89. Also have the skid plate and rubber mat that goes with it. I'm in the NH seacoast area.
Old 10-09-2019, 03:40 PM
Tried ordering new filler and vent hoses for tank but learned that there's 2 styles, 1 flared and 1 straight. Any ideas on figuring out which one I need (it's a front fill tank)? The current hoses are some kind of homemade clear tubing so that doesn't help. I don't want to just order both and return one. I assume the different hose shape and length would put the filler or tank in different positions. Has anyone figured this out before?
Johnny
78 J20 360, TH400 new project
77 CJ5 Straight 6, T-18, 10/14 Bolt, 4.88's, 38's, spring over, stretched rear, fiberglass body, cage
09 JKU Mall crawler
15 JKU Wife's
Old 10-09-2019, 05:31 PM
PM'd you about the tank
Johnny
09 JKU Mall crawler
15 JKU Wife's
Old 10-14-2019, 01:24 PM
May have found an answer to which hose is correct. I asked around and someone suggested that the hoses with flared ends are much shorter and would likely fit a stepside style bed where the filler would be closer to the centerline of the Jeep. I ended up ordering the longer unflaired hoses for my regular bedsides. I'll update when I try to get it back together.
Johnny
09 JKU Mall crawler
15 JKU Wife's
Old 10-14-2019, 03:19 PM
moved this to new thread...
apples vs. oranges
OP was asking about later model poly grand wag tank.
Earlier models aren't the same, and according to your sig. you've got a J20?
Gas tank issues Whitewagon General FSJ Tech 7 07-07-2018 06:33 AM
Winter Boredome Waggy Project Log (Pic Heavy) Dr. Marneaus General FSJ Tech 102 09-24-2012 11:44 AM
A little help with BJ's fuel tank pablo_max General FSJ Tech 36 12-15-2009 11:51 AM
Fuel Tank Issues 8379qtj10 General FSJ Tech 6 08-18-2009 04:02 PM
That leakin gas tank noah's big truck General FSJ Tech 11 04-02-2002 01:38 PM
