Old 11-26-2019, 03:03 PM
mgmann mgmann is offline
Danna 44 axle shaft source
Trying to find a source for a driver's side rear axle shaft with the bearing, etc installed. I'm getting some conflicting information and was wondering if anyone on this board has a source for a shaft? Team Grand Wagoneer sells them in pairs, but I only need one.
Old 11-26-2019, 03:53 PM
I'd try Randies Ring and Pinion in WA
Old 12-04-2019, 11:44 AM
Year, model? I'd go to the WTB forum here and buy used. Your local automotive machine shop can install a new seal/bearing/retainer if you want new bearings. Or try Montana Overland.
Old 12-04-2019, 06:12 PM
brentwood brentwood is offline
I found mine on eBay. Jeeprecyclers probably have some too
1982 Wagoneer w/258, Rusty's 4in spring lift, motorcraft 2100
inner axle shaft length ??s KJ Ryu General FSJ Tech 0 05-31-2009 10:01 AM
88 rear axle shaft inner seal perplexity Rich88 General FSJ Discussion 1 12-18-2008 03:30 PM
Rear axle shaft length?? 84Gw360 General FSJ Tech 0 09-23-2007 11:53 AM
Dana 44 Axle Shaft Removal Big Rob General FSJ Tech 1 05-21-2006 02:54 AM
Tapered rear 44 axle questions Celadus General FSJ Tech 2 07-13-2002 06:07 AM
