Old 06-01-2004, 02:32 PM
Wag the Dog's Avatar
Wag the Dog Wag the Dog is offline
Lightbulb
If you've never seen the McMaster Carr web catalog you should go there now:
http://www.mcmaster.com/
This supply house has just about everything and while not an auto parts store their hardware selection alone is extensive and if you have a full on shop or just a home garage they have many useful items especially for fabrication:
Pipe, Tubing, Hose and Fittings
Pipe and Pipe Fittings • Pipe and Tube Joining Clamps • Pipe and Tube Repair Clamps • Swivel and Rotating Joints • Plastic Tubing • Rubber Tubing • Metal Tubing • Barbed Tube Fittings • Compression Tube Fittings • Instant Tube Fittings • Quick Disconnect Tube Couplings • Quick Clamp and Weld Tube Fittings • Manifolds • Vacuum Hose • Duct Hose • Blowing and Exhaust Hose • Multipurpose Hose • Fire Hose and Adapters • Transfer Hose • Braided Hose Assemblies • Hose and Tube Clamps • Hose Fittings and Couplings • Quick-Disconnect Hose Couplings • Cam and Groove Hose Couplings • Hose Reels • Hose Nozzles
Pumping, Vibrating and Filtering
Sump Pumps • Effluent Pumps • Sewage Ejector Pumps • Open-Area Pumps • Condensate Pumps • Submersible Pumps • Drum Pumps • Fuel Transfer Pumps • Diaphragm Pumps • Magnetic Pumps • Centrifugal Pumps • Flexible Impeller Pumps • Gear Pumps • Metering Pumps • Vacuum Pumps • Jet Pumps • Vibrators • Exhaust Muffler/Filters • Air Intake Filters • Separators • Steam Traps • Strainers • Water Filters • Filter Cartridges • Filter Bags • Oil Skimmers • Oil Filters • Woven Wire Cloth • Sieves and Separator Screens
Process Control and Instrumentation
Metal Ball Valves • Thermoplastic Ball Valves • Butterfly Valves • Gate Valves • Globe Valves • Check Valves • Needle Valves • Solenoid Valves • Pop-Safety Valves • Relief Valves • Regulating Valves • Automatic Control Valves • Float Valves and Floats • Mixing and Plumbing Valves • Plug Valves • Mixers • Water Heaters • Immersion Heaters • Heat Cable • Drum Heaters • Strip Heaters • Cartridge Heaters • Heat Exchangers • Liquid Chillers • Water Purifiers • Liquid Level Sights and Gauges • Liquid Level Switches • Flow Sights • Flowmeters and Totalizers • Flow Switches • Thermometers • Thermistors, Thermocouples and RTDs • Temperature Controls and Recorders • Weather Instruments • Pressure Gauges • Manometers • Pressure Transducers • Pressure Switches • Pressure Recorders • Water Quality Testers and Controllers
Heating, Air Conditioning and Ventilating
Heaters • Air Duct • Thermostats • Enclosure Cooling • Air Conditioners • Fans • Exhaust Fans • Louvers • Roof-Mount Ventilators and Duct Fans • Blowers • Fume Exhausters and Cleaners • Dust Collectors • Air Cleaners and Humidifiers • Desiccants • Air Filters • Dehumidifiers
Lighting and Electrical
Light Bulbs • Ballasts and Lighting Accessories • Fluorescent Lights • Bay Lights • Emergency Lights • Flood Lights • Flashlights • Trouble Lights • Workstation and Machine Lights • Dock Lights • Electrical Cleaners • Testers • Multimeters • Terminal Blocks • Terminals • Connectors • Wire Strippers and Crimpers • Multipole Connectors • Plugs and Receptacles • Sleeving • Heat Shrink Tubing • Wire and Cable • Extension Cords • Outlet Strips • Cord Reels • Conduit and Fittings • Outlet Boxes • Raceway Systems • Cord Grips • Enclosures • Fuses • Fuse Blocks • Circuit Breakers • Bonding and Grounding Equipment • Surge Suppressors and Power Supplies • Transformers • Batteries • Battery Testers, Chargers and Accessories • Generators • Panel Mount Switches • Enclosure Mount Switches • Disconnect and Pendant Switches • Rotary, Toggle and Rocker Switches • Foot Switches • Lighting Controls • Motor Controls • Limit and Snap-Acting Switches • Proximity Switches • Timers • Contactors and Relays
Power Transmission
Hydraulic Pumps • Air Compressors • ASME-Code Pressure Tanks • Condensate Separators and Drain Valves • Compressed Air Dryers • Compressed Air Filters • Compressed Air Regulators • Filter-Regulators-Lubricators • Compressed Air Control Valves • Air Cylinders • Air Slides • Hydraulic Cylinders • Electromechanical Actuators • Linear Actuators and Solenoids • Electric Motors • Air Motors • Speed Reducers • Roller Chain • Sprockets • Bushings • Clutches and Torque Limiters • Timing Belts • Timing Belt Pulleys • V-Belts • V-Belt Pulleys • Round Drive Belts • Round Drive Belt Pulleys • Flat Drive Belts • Flat Drive Belt Pulleys • Gears • Shafts • Linear Bearings • Precision Acme Lead Screws • Ball Screws • Linear Motion • Track Rollers • Drive Rollers • Machine Screw Jacks • Turntables • Plain Bearings • Ball Bearings • Tapered and Needle Bearings • Thrust Bearings • Mounted Bearings • Shaft Collars • Shaft Couplings • Universal Joints • Rod Ends and Linkages • Clevises • Control Cables • Gas Springs • Shock Absorbers • Encoders
Material Handling
Gravity Conveyors • Conveyor Rails and Rollers • Ball Transfers • Powered Conveyors • Conveyor Belts • Overhead Conveyors • Stock Stands • Hand Trucks • Platform Trucks • Carts • Box Trucks and Hampers • Wagons, Trailers and Trailer Accessories • Dollies • Spool and Reel Trucks • Cylinder Trucks • Drum Handling Equipment • Forklift Attachments • Pallet Trucks • Lift Tables • Lift Trucks • Railroad Equipment • Dock Equipment • Plate Mounted Casters • Stem Casters • Track Wheels and Casters • Wheels • Leveling Mounts • Vibration Damping Mounts • Jacks • Wire Rope • Chain • Fibrous Rope • Shackles • Hooks • Snaps • Turnbuckles • Sheaves and Blocks • Winches • Hoists • Trolleys • Cranes • Lifting Clamps and Magnets • Slings • Hoist Rings • Eyebolts • Cable Ties • Straps and Hangers • U-Bolts • Strut Channel • Tie Downs • Bags • Boxes and Packing • Security Seals • Stretch Wrap and Strapping • Tension and Compression Gauges • Scales • Counters
Storage
Drawer Cabinets • Bin-Box Racks • Bin-Box Cabinets • Shelf Cabinets • Safety Cabinets • Shelving • Bulk and Pallet Racks • Pallets • Cantilever Racks • Lockers • Partitions and Buildings • Structural Rail Fittings • Structural Framing Systems • Workbenches • Tables • Desks and Workstations • Chairs • Stools and Seats • File Cabinets • Coat Racks • Food-Service Equipment • Bottles and Jars • Squeeze Bottles • Sprayers • Pails • Cans and Safety Cans • Scoops • Funnels • Drum Faucets, Vents and Plugs • Drums • Spill-Control Containers • Storage Tanks • Pans • Bin Boxes • Tote Boxes • Bulk Containers • Storage Boxes and Chests • Bags and Belt Pouches • Garbage Bags • Waste Disposal Equipment • Waste Containers • Dump Trucks and Hoppers • Urns and Ashtrays
Protective Clothing and Equipment Communication and Office Supplies
Gloves • Boots and Shoes • Protective Clothing • Fall Protection • Emergency Wash Stations • First Aid Supplies • Safety Glasses • Welding Glasses and Helmets • Hard Hats • Ear Plugs • Gas Detectors • Respirators • Protective and Welding Screens • Safety Mirrors • Fire Protection • Intercoms and Radios • Telephones • Data Cables • Speakers • Horns, Bells and Alarms • Warning Lights • Exit Lights • Safety Signs • Bulletin Boards and Dry Erase Boards • Flags • Vehicle Safety Equipment • Traffic and Crowd Control • Stencils and Markers • Hand Stamps • Engravers • Tags • Labels • Clocks • Timers • Office Supplies • Computer Accessories • Drafting Equipment • Reference Books
Plumbing and Janitorial
Water Coolers • Toilets and Urinals • Showers • Sinks • Faucets • Soap and Soap Dispensers • Test Plugs • Plungers and Drain Cleaners • Cleaners • Brushes • Wipes • Spill Control Sorbents • Mops • Brooms • Vacuums • Pressure Washers • Garden Hose • Spray Nozzles • Matting • Stair Treads • Grating • Shovels and Scoops • Landscape Equipment • Bird and Pest Control • Concrete, Asphalt and Roof Repair • Tarps • Paint and Coatings • Paint Brushes • Step Stands • Step Ladders • Work Platforms • Rolling Platform Ladders • Scaffolds
Machinery Maintenance
Lubricants • Grease • Oils • Metalworking Fluids and Oils • Grease Guns • Grease Fittings • Oilers • Coolant Systems • Knobs • Handles • Leak Detectors • Vibration Meters • Tachometers • Stroboscopes • Inspection Mirrors • Vehicle Maintenance
Measuring, Leveling and Inspecting
Rules • Tape Rules • Distance Measuring Tools • Squares and Protractors • Layout Tools • Screw Checkers and Gauges • Calipers • Micrometers • Bore Gauges • Depth Micrometers and Gauges • Gauge Blocks • Electronic and Dial Indicators • Feeler Gauges • Plug and Thread Gauges • Levels • Angle Indicators • Surface Plates • V-Blocks • Magnifiers • Microscopes • Ultraviolet Lighting • Flaw Detectors • Coating Thickness Gauges • Hardness Testers
Fabricating, Cutting and Sawing
Punches • Presses and Brakes • Sheet Metal Formers • Benders • Tubing Tools • Tube and Pipe Cutters • Gasket Cutters • Paper Trimmers • Glass and Tile Cutters • Drum Deheaders • Bolt and Wire Cutters • Cable Cutters • Snips • Shears and Scissors • Electric and Sheet Cutting Shears • Knives • Chisels • Scrapers • Band Saws and Blades • Hacksaws • Reciprocating Saws • Jigsaws • Hole Cutters and Saws • Table and Miter Saws • Circular Saws and Blades • Cutoff Saws and Wheels
Machining and Clamping
Pipe-Threading Tools • Tapping Tools • Taps • Dies • Thread Restoring Tools • Air Drills • Cordless Drills • Electric Drills • Hammer Drills and Rotary Hammers • Magnetic-Base Drills • Drill Presses • Drill Chucks, Arbors and Keys • Drill Bit Storage • Drill Bits • Wood-Boring Bits • Routers • Router Bits • Countersinks and Counterbores • Reamers • End Mills • Milling Cutters • Broaches • Milling Machine Accessories • Boring Tools • Lathes • Tool Posts and Holders • Cutoff Blades and Tool Bits • Carbide Inserts • Live Centers • Collets and Collet Fixtures • Knurls • Vises • Support Arms and Mounts • Tool Balancers • Toggle Clamps • Spring and Plier Clamps • C-Clamps • Bar Clamps • Setup Clamps • Spring and Ball Plungers • Drill Jig Bushings
Parts Treating, Abrasives and Finishing
Air Ionizers and Air Knives • Blowoff Nozzles • Blowguns • Ultrasonic Parts Cleaners • Parts Washers • Wire Cloth Baskets • Sandblasting Media and Equipment • Heat Guns, Blowers and Dryers • Ovens and Furnaces • Melting Pots • Hot Plates • Files and Rasps • Deburring Tools • Burs and Rotary Files • Grinding Wheels • Mounted Abrasive Points • Toolroom Grinding Wheels • Grinding Wheel Dressers • Die and Angle Grinders • Bench Grinders • Flexible Shaft Tools • Stones, Sharpeners and Hones • Vibratory Media and Machines • Buffing Compounds and Buffs • Lapping Compounds • Power Brushes • Twisted-Wire Brushes • Hand Brushes • Sanders • Sanding Sheets and Rolls • Sanding Discs • Sanding Belts • Sanding Drums and Wheels • Nylon Mesh Abrasives
Hand Tools
Bearing and Gear Pullers • Bearing Heaters • Retrieving Tools • Suction and Vacuum Cups and Lifters • Positioning Tools, Tweezers and Tongs • Pliers • Diagonal Cutting Pliers • Retaining-Ring Pliers • Strap Wrenches • Pipe and Adjustable Wrenches • Spanner and Drum Wrenches • Open-End Wrenches • Combination Wrenches • Box Wrenches • Tool Sets • Sockets and Wrenches • Impact Sockets and Wrenches • Powered Sockets and Wrenches • Impact Wrenches • Torque Wrenches • Powered Screwdrivers and Bits • Screwdrivers • Nutdrivers • Torx Keys and Drivers • Hex Keys and Drivers • Screw and Pipe Extractors • Nonsparking Tools • Nonmarring Hammers • Dead Blow Hammers • Sledges • Nail Hammers and Hatchets • Pneumatic Hammers • Pry Bars and Wedges
Hardware
Window Coverings • Window Hardware • Door Weatherstripping • Vinyl Strip Doors • Traffic Doors • Air Curtains • Room Dividers • Metal Doors • Folding Gates • Access Doors and Hatches • Door Track and Hangers • Door Holders and Bumpers • Door Locksets • Door Closers • Door Openers • Exit Devices • Magnetic Contacts • Access Control Devices • Electric Strikes • Video Surveillance • Key Control • Lockouts • Padlocks • Hasps • Cam Locks • Door Bolts • Door Latches • Door Catches • Pull Handles • Hinges • Lid Supports • Drawer Slides • Braces and Brackets • Tool Holder Racks • Hooks and Hangers
Fastening and Sealing
Wood Screws • Sheet Metal Screws • Self-Drilling Screws • Drywall Screws • Machine Screws • Thumb Screws • Shoulder Screws • Set Screws • Socket Head Cap Screws • Cap Screws and Bolts • Threaded Studs and Rods • Acme Threaded Products • Nuts • Washers and Shims • Binding Screws • Spacers and Standoffs • Retaining Rings • Captive Fasteners • Helical Inserts • Rivet Studs and Nuts • Pins • Machine Keys • Rivets • Blind Rivets and Tools • Anchors • Nails • Nailers • Staplers • Staples • Welding Equipment • Pressure Regulators • Welding Hose and Cylinders • Propane Torches • Soldering Equipment • Brazing Alloys • Epoxies • Super Glues • Thread Sealants • Silicones • Construction Adhesives • Contact Cements • Hot Melts • Adhesive Dispensing Tools • Electrical and Repair Tape • Carton Sealing Tape • Masking and Specialty Tape • Foil Tape • Duct Tape • Foam Tape • Hook and Loop • Seals • Gaskets • O-Rings • Compression Packing • Ring Seals
Raw Materials and Springs
Felt • Fabrics • Brake and Clutch Lining • Thermoplastic Mesh • Thermal Insulation • Pipe and Tube Insulation • Sound Absorbers • Rubber and Foam Rubber • Polyurethane • Plastics • Ceramics • Glass • Composite Materials • Metals • Expanded Metal • Perforated Materials • Foils • Shim Stock • Wire • Magnets • Bumpers • Edge Trim • Grommets • Grips, Caps and Plugs • Bellows • Springs
© 2004 McMaster-Carr Supply Company
McMaster ® and McMaster-Carr ® are registered trademarks of McMaster-Carr Supply Company. Trademarks identified with products sold on this web site are the property of their respective owners, not McMaster-Carr Supply Company.
83 Wagoneer Ltd. TFI & AM/FM cassette player!
Old 06-01-2004, 03:13 PM
AMX factor's Avatar
AMX factor AMX factor is offline
Nice company. Kinda like Grainger.
"I'm sick of this sickness, don't touch me you'll get this."
1984 GWag "orphan" for sale
2 x 1975 Matador "murder machines"
1970 SST390 Javelin 10 yr project!
Old 06-01-2004, 03:57 PM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
and MSC Industrial Supply
