Does anybody think that putting a 4.3L Oldsmobile Diesel in my Cherokee is a terrible idea? The wieght and power doesn't make it much different from my 258, but I'm sure there is something big that I overlooked that you folks out there will catch.
4.3L oldmobile diesel motor in a cherokee chief
I want the diesel motor so I could try the Vegitable oil/grease/biodiesel stuff.- Doug
MY HEEP:
daily driver 83' Chero Cheif WT, 3" lift, 6.2L diesel, Getrag 5-speed, NP241, 33" TSLs (scratch that, i sold them to get money to finish the diesel swap), a Superwinch 9K
Interesting question cause I'm a dsl fan but not familiar at all with the 4.3L.
In regards to this link: http://www.bestautojobs.com/shop/cra..._737ioy_8.html Anyone have any comments on these motors? $1100 for a rebuilt dsl short block seems awfully cheap?joe
In regards to this link: http://www.bestautojobs.com/shop/cra..._737ioy_8.html Anyone have any comments on these motors? $1100 for a rebuilt dsl short block seems awfully cheap?Daily Driver 2008 Wrangler Sahara
Drats! I got there from following a google olds/4.3/diesel link and didn't catch it sent me to a gaso link.
Doh! Time to brew up the 2nd pot of starter fluid...obviously the first pot of coffee didn't do it's stuff.joe
I am not familiar with the 4.3L Olds diesel either. I just assumed that, as the Olds Diesel was based on their 350 (5.7L) gas motor and Olds also had a 260 CID (4.3L) V8 that might have been made into a diesel,too???
The bottom end of that Olds diesel was never meant for that kind of compression and there must have been a reason almost all of them were eventually converted to gas.
Didn't know they made one but here it is, '82-'85 6 cyl 263 Diesel 85hp-165 torque! Will that even move an FSJ. 1980 V8-260 Diesel 90hp-170 torque. Pass! Get something with balls if your going to go through all the work to do the swap.David "If all else fails, read the instructions."
Great little engine. I had one in an '83 Buick Century. Great mileage...zero issues with it. It moved that little Buick along just fine. Now if I could just find one for my home generator set up. [img]smile.gif[/img]79 Cherokee Chief WT "RDBLOK" warmed over 360, TH400/QT, 4.10 Truetrac F/Detroit Locker R, 4" Skyjacker Softride System, Rancho 9000 shocks with in cab adjust, Hydroboost brakes, 33" BFG Mud Terrains
In my opinion, that thing is a dog. My dad had three of those, two Delta 88 4 door sedans (one blew up, so they replaced the whole car) and a Delta 88 wagon. He threw a bunch of miles on them, but they had a 0-60 time of approximately 2 hours. I don't recall it being anything special in horsepower or torque. They were also very dirty diesels, not like the modern diesels we see today.1975 Cherokee Chief WT
I would consider the GM 6.2/6.5 the minimum entry level diesels for out FSJ's. Easy swap, cheap to do, 21+ MPG and the Blazer with the 6.2 was rated at 29 mpg.
Optimum diesel swap would of course be either the Cummins 4bt or 6bt swap.
I have owned a 2001 6BT Dodge truck and now have a 2004.5 600 series cummins Dodge 3500 truck. Got 21 MPG in a 2200 mile trip to Ouray and got 14 mpg in the 2004.5 in a trip to Ouray. In my opinion, the pre 600 series engines are superior for fuel mileage and can easily be upgraded for power.
I think 30 MPG would be so easy to get with a 4BT in a FSJ.In Process: 91 Wagoneer, D61/71 axles with 3.07 gearing, NV4500, NP205. Cummins 6BT.
(hijack) I put 170,000 miles on a '93 Didge dually with a Cummins and an automatic. Many of them came while towing a 7,200 pound car/trailer combo. I love that engine, and with a few simple mods it ran quite well. It also delivered about 18 mpg in daily driving including towing. A pure highway trip would get me about 21 MPG. (end hijack)
