About a week ago I dragged the "67 out of the hay shed and around to the shop. I felt really guilty about how little time I've spent working on it. I was worried about whether or not she would even start. I charged the battery for a long time on a slow charge and stuck the end of the fuel line in a can of fresh gas but no luck before the battery went dead. I put the charger back on it and tried again today and after pouring some gas in the carb she fired right up! I need to get the oil changed and get to work on the brakes now.
A good day with the '67
i hate you wish i had one as well...... the future X wife would kill me if i got another money pit
steveAbort? Retry? Ignore? >
Originally posted by Tripwirei hate you wish i had one as well...... the future X wife would kill me if i got another money pit
steveChuck McTruck 71 J4000
(Chuck McTruck Build Thread)
00 Baby Cherokee
Yesterday I removed the fuel tank so I could clean it out and get it back to supplying fuel for the truck. It's an old steel tank with a few dents but thankfully no leaks. It has a drain plug welded into the bottom but it wouldn't turn so I left well-enough alone and quit trying to remove it. I did find an old repair made with some sort of epoxy patching material but its holding with no leaking so far! I rinsed it out several times with fresh gas and got quite a bit of sediment and a lot of rust flakes out. I'm using two in-line filters between the tank and the carb so I feel OK using it until I figure out what to do about a replacement. Right now its mounted on square tubing hanging between the frame rails behind the rear axle. I'm sure I'll eventually replace it with a new plastic tank but this will work for now.Last edited by jpcoutts; 08-08-2018, 01:10 PM.Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Does your sending unit work Jim? If so keep it when you replace the tank. I've got three aftermarket sending units in my various Jeeps and they all read 1/4 tank low. The one in my 71 used to read right, then dropped to reading 1/4 low. The other two did it out of the box.Thomas Russell
1971 Gladiator J2000 Platform-Stake Dump 350/T18
1970 Gladiator J3000 3407Z Camper Truck 350/T181968 Wagoneer Custom 327/TH400
Thanks for the heads-up. I'll have to be really careful removing it so I won't destroy it in the process. I wonder if the issue is a resistance issue in the circuit between the sender and the gauge? I replaced the sending unit in the J20 when I replaced the tank and it reads 1/4 too high. I think I can correct that by bending the float arm but I haven't gotten around to it yet!Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
No link with pics at the moment. I got frustrated with PB and haven't even tried in a while. What's it like working on a 327 over there?Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Originally posted by jpcouttsNo link with pics at the moment. I got frustrated with PB and haven't even tried in a while. What's it like working on a 327 over there?
If it needs a rebuild , i guess it won't be simple..J10 sportside '81, J10 Golden Eagle '77, Wagoneer '65, Gladiator '64 + parts rigs
