I bought this a few months ago but just really got started on it. I it a 78 Cherokee Chief
Here is hopefully what it will have when done
I posted this in the off-road tech because this is an off-road build up so the entire project will be in the same thread
Engine: 2002 4.0 L6
Trans TH400
Transfer case NP 205
Axles D60, 14bolt
Gears 4.56 Detroit
Tires 38-> 42 range
SOA and Shackle Flip
I started today working on installing the engine.
I found out that I can not use the stock flex plate, because the torque converter had 3 bolts and the flex plate was drilled for 4 bolts. I determined that I could just use the stock flex plate from the 360 since it had the same bolt pattern on the crank as the 4.0. I will have to use the starter from the 360, because the ring gear on the flex plate is offset in a differ place and the 4.0 starter gear will not reach out far enough.
I was going to use the stock 258 engine mounts on the engine to make things simpler but when I try to bolt the mounts to the block I found out that the 4.0 block was machined different than the older 258. So I decided to make my own using the TJ Mounts already on the engine.
I bolt the engine up to the tranny to see how everything was going to fit and so I could start making the engine mounts.
After measuring a few things I determined that the engine needs to move back about 4", where it sits now the fan will be though the radiator.
You can see the radiator support mount hole in the frame is right where the radiator is.
I checked to see if I had enough room to move the engine back far enough. I don't think that will be too much of a problem. I have plenty of room between the back of the engine and the fire wall. I think I will still clear the brake booster but it will be close.
Everything else fits in there pretty well. Here are the rest of the pics. I will post my progress each step of the way
[ September 11, 2005, 07:43 PM: Message edited by: Carl Rasmussen ]
Engine: 2002 4.0 L6
Trans TH400
Axles D60, 14bolt
Gears 4.56 Detroit
Tires 38-> 42 range
