Old 06-09-2019, 04:26 PM
LMAO...
Tried to clean up and reinstall the timing cover on my 90 today.
Huge crack...gee wonder why it leaked?
I mean the repair is awesomeness!!!
Sealer-ish or bondo-ish stuff is oil resistant is it not?
1994 Caprice wagon
Old 06-10-2019, 11:20 AM
The body man when I worked at the Jeep dealership would repair leaky gas tanks with bondo. It worked ... maybe all the alcohol in modern fuels would be a problem today. Something like this would be ok, I'd think - https://www.permatex.com/products/ad...-metal-filler/
Old 06-10-2019, 06:37 PM
letank's Avatar
letank letank is offline
me too...
about 20 years ago I cracked the timing cover on the 74, too big of a hammer to drive the cranshaft seal ... cleaned the area and put a bead of black silicone to cover both side of the crack... still ok... about the same area
as for the gas tank, JB weld endured years of our great calif gas
Michel
Old 06-11-2019, 10:30 AM
brubakes's Avatar
brubakes brubakes is offline
Dear lord.....
FSJless.... for now....
Old 06-11-2019, 05:57 PM
acct21's Avatar
acct21 acct21 is offline
That is awful — but looks to be in a pretty non-critical area. Could you drill both ends of the crack and have it brazed/TIG’d?
Old 06-11-2019, 06:17 PM
Yes can be repaired but wow someone paid to rebuild the engine and then that???
Cover has been leaking coolant for couple years and seeping oil for longer.
Not drip oil leak just enough to slather the front of engine in nice layer of goo.
Just don't get people that do this kinda stupid.
Why bandaid it? Just fix it right or replace it...sheesh!
1994 Caprice wagon
Old 06-11-2019, 09:35 PM
ZackN920's Avatar
ZackN920 ZackN920 is offline
Ha, what options are there for replacement? Nobody makes a good one (from what i've read) Only option is to fix what ya got or get a used cover.
oh, and in that first pic, it looks kinda like jb-weld slathered on it. Probably just the pic though...
...still kinda rusty
The other's
1926 Dodge Brothers 5 pass. Business Sedan 212-I4, 3 speed, CRANK START (new long term project)
1987 Lincoln Town Car "Signature Series" 5.0, AOD unknown gears
1987 Dodge Dakota LE 3.9,A999TF,3.90gears(DD)
1994 GMC 'Burban L05-5.7,4L60E,3.73gears(DD)
2001 Jeep Cherokee Sport 4.0,AW4,3.73gears(thinkin of selling)
Old 06-13-2019, 02:08 PM
360 AMC
Hahah! What's even better is it looks like he didn't even take it off to fix it! I bet he saw oil leaking out, so he wiped it off with some degreaser, got some goop that he had sitting on his shelf and slathered away! LOL!!! Did this wagoneer get serviced by the same shop that did your Mustang?!
Old 06-14-2019, 04:13 AM
JeepsGot360's Avatar
JeepsGot360 JeepsGot360 is offline
I bought the timing cover off of Rock Auto OMIX-ADA P/N 1745705 159.79$ Worked great have had no issues since it was installed in April 2017. I think people have problems when they don't match the cam gear and distributor gears.
78 J10
84 CJ8
79 Wagoneer
43 GPW
Battery Drain marshotel General FSJ Tech 17 07-27-2013 06:37 PM
88 GW dies when it gets hot mgmann General FSJ Tech 26 07-16-2013 01:03 PM
727 rant Sambo General FSJ Tech 13 07-14-2013 02:17 PM
TFI install report Rich88 General FSJ Discussion 32 06-27-2013 08:04 AM
