Old 06-01-2019, 01:15 PM
Mikel's Avatar
Mikel Mikel is offline
Brake hose interference
Hello,
I've put new brake hoses in a friend's '75 Cherokee. The vehicle is all stock and the hoses rub against the shock absorbers, which can be a problem over time.
Before I "make things fit", does anything here look wrong?
Thanks.
1969 M715 6x6
1963 J300 Swivel frame
Old 06-01-2019, 02:22 PM
should not be a problem but if you are worried, find a piece of rubber hose and some zip ties and wrap the hose where it rubs on shock.
Old 06-05-2019, 01:49 PM
Somehow I think you should rotate the hose on the frame bracket so it does not bend toward the shock. Maybe too simple, but I think you can do that.
Old 06-05-2019, 02:14 PM
77Deepj20 77Deepj20 is offline
The hose looks like it has a twist In it. Take it off the banjo bolt, let it relax and reinstall.
1977 j20. Dana 60's, 4:10's Chrysler 360/np435/NWF blackbox/np203
Hummer military 24 bolt wheels and 37" mt/r's.
Old 06-08-2019, 11:42 PM
johnwaynejeep3 johnwaynejeep3 is offline
Ditto what Deep J20 said. The ribs along the flexible line are an indication of a twist, they should not spiral around the brake line.
I've seen people use small springs from a general purpose spring kit to pull the brake line away from any moving parts. Works pretty well.
75 Chevy C10
07 Wrangler X
76 J20 ambulance - Sold - bad decision
85 Grand Wagoneer - gave away - not my decision
84 Grand Wagoneer - parted out - good decision
I like my baby JK, but I want grandpa SJ again.
Old 06-09-2019, 04:52 AM
Mikel's Avatar
Thank you guys. I rotated the hoses 90 deg on the caliper side and everything is perfect now.
1969 M715 6x6
Rear Brake Hose after Lift? RAMBLINFSJ General FSJ Tech 6 11-05-2013 07:09 AM
Need help for order Brake Hose from Rockauto cma General FSJ Tech 8 12-16-2012 02:33 PM
Axle Swap and What I Learned (Part 1 of 2) Thomas792 General FSJ Discussion 1 12-03-2012 07:18 AM
brake hose...quck question Down Yonder General FSJ Tech 0 04-25-2009 06:49 AM
no brake or tail lights..but turn signals! (EDIT:FIXED!) griffsyj General FSJ Tech 6 03-24-2009 10:22 AM
