Old 05-26-2019, 06:38 PM
rws31's Avatar
rws31 rws31 is offline
Integrated Heater A/C system
Has anyone tried to combine the Heater core into the inside and route the air flow from the A/C fan into the heater/defrost duct work. Looks like it might be possible with a very small heater core installed into the heater/defrost duct work. It would be on a 1989 system. If I can find a really small heater core, I might give it a shot. Would have to add another flapper of some kind to keep air out of heater side when the A/C is on and install an inline heater valve in heater core water line to control heat temp. Curious if anyone has done it.
Live in Florida so how much heat do we really need huh.
89 GW, 454, 700R4, 241C, 411's with posi's, 9" rearend, 2500 stall, lifted, and lots more to do.
1988 Ramcharger
1999 International 4700 Crew Cab 4X4, custom step side bed
Old 06-07-2019, 09:44 AM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
Motorcycle oil cooler, aftermarket trans oil cooler, even smaller would be old school steering fluid cooler.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Old 06-07-2019, 11:39 AM
There are aftermarket under-dash units that include both heating and air conditioning. You'd end up replacing both the heater and air conditoner with a new unit. You could keep the existing condensor coil, compressor mount and possibly the compressor too.
Old 06-07-2019, 08:55 PM
Mass's Avatar
Mass Mass is offline
I'm interested in this also. I don't like my knees freezing and windows condensing when it's humid or raining outside.
89' GW 6BT Cummins
Old 06-09-2019, 05:19 PM
rws31's Avatar
I considered the oil/trans cooler thing but most have smaller lines. I might have to keep looking until I find the right thing and keep moving forward with my build. Wouldn't be to hard to yank the A/C back out. Seems like an easy fix with the right heater core. I find something, I will post it up.
1988 Ramcharger
How many Amps should the a/c and heater motors draw? mdcptman General FSJ Tech 11 03-28-2015 12:45 PM
A/C system questions Jeep Craze General FSJ Tech 6 07-14-2009 09:34 PM
A/C system ???s...Jeep and Chevy together Langdon General FSJ Tech 6 07-09-2009 07:40 AM
Heater - A/C - Fan control Question Symer Salient General FSJ Tech 6 03-11-2005 09:21 AM
"an exhaust system can also be too efficient." Jerk General FSJ Tech 25 09-12-2002 03:58 PM
