Old 04-04-2019, 09:16 AM
Beach_Dude's Avatar
Beach_Dude Beach_Dude is offline
AC Evap Core Housing material?
Searching for what the type of plastic the AC Evap Core Housing is made of?
The drain line barb that stuck out from the bottom broke off and I need to fabricate something to weld to the type of plastic.
If anyhow has alternative techniques, I'm all ears!
But, I'm thinking it's ABS.
Does anyone know?
1977 Jeep Cherokee Chief
360 w/ MC 4350
Modified header exhaust w/ported AIR Injection
Slightly modified suspection
Old 04-04-2019, 09:42 AM
If it was mine I'd just epoxy a new barb on there if the broken piece is mia.
Trying to plastic weld aged 70's plastics usually just gets ugly.
1994 Caprice wagon
Old 04-04-2019, 10:20 AM
Beach_Dude's Avatar
This is true...
I was going to get a new barb, cut to match the surface of the housing, sand the surface of both sides, the weld together using whichever chemical weld matches the plastics if it is ABS...
That would hold better than epoxy, wouldn't it?
If it isn't ABS... If not, then I'd epoxy.
360 w/ MC 4350
Old 04-05-2019, 11:47 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Get some Q-Bond. It glues most any kind of plastic and fills in cracks very well.
It's a powder that you sprinkle into the crack, break, or space between parts that you want to glue then drip a liquid hardener onto. It sets instantly into plastic that can be shaped, ground, or filed. You can build it up too. I love it.
Old 06-10-2019, 10:45 PM
Beach_Dude's Avatar
Super easy...
Ended up at home crappo, got a cheap 3/4 male thread to Barb sitting.
But the threading off with a saw, sanded down with a 400 grit to make it at least flat but rough.
Used a jb weld pUtty and BOOM!
360 w/ MC 4350
63-72 Heater Core Different Size? red mistress General FSJ Tech 15 01-07-2011 07:18 PM
Chevy Heater Core Housing,Same As Stock Housing? Rompn General FSJ Tech 2 02-01-2005 05:40 PM
under-dash AC housing... skid2964 General FSJ Tech 9 03-01-2004 01:23 PM
Article on Leaf Spring that may be interesting to some. Joker's '88 GW General FSJ Tech 2 10-28-2001 03:14 AM
(TOM) Article on Leaf Spring that may be interesting to some. Joker's '88 GW Suspension and Steering 0 10-28-2001 01:38 AM
