Old 02-17-2015, 08:00 PM
mattparliament's Avatar
mattparliament mattparliament is offline
Mag Wheels, nasty to decent!
Tons of road grime and I've never touched them... Spent half an hour today on this one, fine sand flapper wheel then some turtle wax chrome polish (equivalent to 8000 grit slime), turned out decent, doesn't look like chrome but pretty nice and big improvement!
after powerwashing:
Finished for now...
1976 Cherokee 401 Quadratrac
4" Rough Country Spring lift 31" tires
All MSD ignition system
EZ EFI status: Running Smooth!
Dakota Seats
Powertrax No-slip lunchbox rear locker
Amp meter delete
Two Wire 94Amp Alternator upgrade
Old 02-17-2015, 10:02 PM
now hit it with some of this.
http://www.zoro.com/i/G0778653/?utm_...gxa Qode3oA5A
easily the best polish available.
Old 02-18-2015, 08:44 AM
Strode's Avatar
Strode Strode is offline
1st Chair, Cowbell
Matt, have you tried those powerball things? Harbor Freight has a knockoff powerball to go on the end of your drill. The real powerballs are expensive, but those work ok.
Ristow's Bunker
Old 02-18-2015, 09:07 AM
Ya I used the powerball thingy along with a cotton polishing wheel. I thought the cotton wheel along with some rubbing compound would work well but it did nothing! At least not very fast!
Dakota Seats
Amp meter delete
Old 02-18-2015, 05:30 PM
78J10honcho's Avatar
78J10honcho 78J10honcho is offline
Try cleaning it with some zep 505 cleaner first. It is shocking how well it works. I get it at the Home Depot.
Ben
78 j10 honcho 360/th400/d20 (sunday driver)...97 F-350 crew-cab 4x4 5-spd PSD (tow rig)
Old 02-20-2015, 03:48 PM
DarkMonohue's Avatar
Shakes hands with danger
Flap wheels are pretty aggressive, and it looks like it did a lot of damage to the surface. If you want to go back and clean it up you'll be in for some hard time with progressively finer paper before you go after it with any compound.
Old 02-20-2015, 04:16 PM
Pic makes it look worse than it is actually, they are not damaged, I used a very very fine flap with no force and slow speed.... Took this pic before I finished up too...
Dakota Seats
Amp meter delete
Old 02-20-2015, 05:13 PM
WHSII's Avatar
WHSII WHSII is offline
Hack-Priss
From a man who swears he is not "Prissy", this information seems to be very Prissy!
WH
Herbina 1987 Grand Wagoneer
Old 02-20-2015, 07:21 PM
mokurt mokurt is offline
Powder coat!
1967 J2000
1985 CJ7
Old 02-21-2015, 02:02 AM
Wgnmaster22 Wgnmaster22 is offline
I have the same wheels and used the Mother's powerballs & their metal polish.
Mine looked as bad as yours and after several hours with the cordless drill and a pile of towels for removing the polish, they absolutely shine like a mirror.
IMHO, it was well worth the time and $$ to get that result.
'78 Wagoneer w/"Improved" 401 w/AFB, custom cam, etc
Q-Trac w/low-range unit & 3:54's
Rancho 9000's w/under-dash controller
Old 02-21-2015, 08:43 AM
DieselSJ's Avatar
DieselSJ DieselSJ is offline
Originally Posted by mokurt
Powder coat!
Ceramic coat. They have a shiny silver one available that looks almost like polished aluminum.
-99 XJ Limited.
Old 02-21-2015, 01:13 PM
Yes you are correct.
1967 J2000
1985 CJ7
Old 02-21-2015, 01:20 PM
link please!!!!
Dakota Seats
Amp meter delete
Old 02-21-2015, 02:28 PM
Originally Posted by mattparliament
link please!!!!
Here's one......
http://www.calchrome.com/service_fusioncoat.php
Search the net.
1967 J2000
1985 CJ7
Old 06-08-2019, 04:26 PM
post resurrection! I finally polished them again and duracoated them, turned out good!
the wife did the first one!
Dakota Seats
Amp meter delete
Old 06-09-2019, 07:12 AM
looks good. i should do that to the rears on my cabover. they're the now 15 years old alcoa bright coated wheels and the coating is now shot. kinda like the bumpers on the GW's,can't really do much with them.
Old 06-09-2019, 08:51 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
great job.
and cool wife to get into that !
cudos !
dave in NC
Best place to get some wheels... Help! Other options? duncanstives General FSJ Discussion 28 03-24-2009 10:21 AM
Silverado Wheels on 79 Cherk? ABN82MP General FSJ Discussion 6 03-23-2009 12:50 PM
w/t steel wheels vs. wagoneer wheels? AlsChopShop General FSJ Tech 2 05-19-2006 02:09 AM
Anyone have re centered hummer wheels? JeepsAndGuns Off-Road FSJ Tech 8 01-01-2006 02:00 PM
Wheels wheels wheels waggylady General FSJ Tech 9 10-14-2005 12:03 AM
