Old 03-16-2013, 03:25 PM
Crist Clapper's Avatar
I'm being stalked by Steve... Save me!
Headliner Material: Different Grades?
In the choices of headliner material... Are there different grades/quality choices? Experiences? Suggestions? Thanks!
1990 Grand Wagoneer:
1987 XJ Wagoneer Limited:
Desiree - def: “Much Desired” [orig: French] Desirable Charcoal Gray façade, Wood-grain vêneers,and Tan Leather éssentials"
Member, FSJ Prissy Restoration Association (FJS-PRIS)
Old 03-16-2013, 03:36 PM
hookedup50 hookedup50 is offline
Thats a good question. I used the cordavan headliner from bj's and it was a match. It has not faded or sagged in five years, and I self installed it. I'm curious about grades as McParts store has the color I need for my pickup, and don't want to go through the effort and have it fade or sag. Subscribed
Jennifer: 89 GW 360/727/D44 2"lift 31" BF KM2
Harriett: 97 chevy 2500 ext cab P/U 6.5 TD
Lorraine: 73 Datsun 240z
07 Colorado
http://s1196.photobucket.com/albums/aa416/hookedup50/
Old 03-16-2013, 05:19 PM
81cherokee laredo's Avatar
81cherokee laredo 81cherokee laredo is offline
There is a difference, when doing the Laredo I bought some from an apolstery shop, unfortunately I didn't end up getting enough for both headliners. I ended up just doing the front in that material. When it came time to do the back liner I just grabed some from Mcpart boys.. Looked good until I got it installed. The black was not as black as the front liner, it wasent that it wasn't black it just didn't have the same thread count so it looked lighter. I'm curious on where BJ's/ TGW get they're liners from as I'm about to order some for the Waggy.
Dan
81 Cherokee Laredo- 360 727 NP219 SOA/SF 35 Coopers 4.56 Gears
83 Cherokee - Katy- long term project
89 Grand Wagoneer- 360 727 NP229 31x10.50's on slot rims
Old 03-21-2013, 07:26 AM
~BUMP~
~BUMP~
Old 03-21-2013, 01:03 PM
Mikeswagon's Avatar
Mikeswagon Mikeswagon is offline
i am rebuilding mine with Alcantara...will post results in a short time.
89 Grand Wagoneer, work in progress
360, Edelbrock 1400, Performer Cam/Lifter/Manifold, Carter 4594 el. fuel pump, Skip White HEI
Old 03-21-2013, 03:07 PM
RamJetFSJ RamJetFSJ is offline
I just did mine in Charcoal suede from material I got from yourautotrim.com. Came out pretty darn good for my first headliner job.
Ben Haines
1980 Wagoneer - GM Perf. Ram Jet 350 crate motor, built 700R4, NP208, 4" lift, 33x10.5 tires.
Old 03-21-2013, 03:09 PM
Mikeswagon's Avatar
Old 03-21-2013, 05:44 PM
Oakknoll's Avatar
Oakknoll Oakknoll is offline
I just did mine today using the fabric material from BJ's. It came out pretty good. I had never done anything like that before, but it was not difficult and I got good results. I did not use the adhesive that came from BJ's I used the 3M adhesive on the reccommendation of others on here.
Peter
1984 J-10
1982 CJ-8
1982 Wagoneer
2007 Commander
2012 Wrangler
1980 Cherokee (for parts)
Old 03-22-2013, 12:23 PM
Originally Posted by Mikeswagon
Agreed, Ill snap some this weekend. Was hoping to finish up my sunvisors first though.
Ben Haines
Old 03-22-2013, 02:23 PM
Frank's Avatar
Frank Frank is offline
I've done two. The first was from an online outlet (American Upholstery, IIRC) and the second time, the material came from Joanne's Fabrics. The Joanne's material was less 'beefy' but both differed from the original as I could see the fabric's substrate material where the original was all nappy.
Both held up well and were comparable to the original, it's just they were not original. I think it's splitting hairs to be honest and the finished product looks great.
Frank
'88 Grand Wagoneer (Almond), "Sluggo" (RIP)
'88 Grand Wagoneer, (Baltic Blue) "Sluggo II" (RIP)
'89 Grand Wagoneer, (Dover Grey) "Sluggo III", keeping my hobby alive!
Old 03-22-2013, 02:28 PM
Thanks all! From the responses... Seems there are not different qualities of headliner material. So... Off to shop with our favorite venders!
headliner material 84Waggie General FSJ Discussion 23 05-13-2015 05:57 PM
Headliner material ? Tzummie General FSJ Tech 2 05-06-2008 08:31 AM
nutmeg headliner material Tzummie General FSJ Discussion 2 12-22-2007 02:06 PM
headliner material ,cant find orig type drives mopars General FSJ Tech 4 11-09-2004 10:39 PM
Any tips on removing/installing headliner material Matthew W. Woodruff General FSJ Tech 9 08-28-2003 02:12 PM
