Old 11-04-2020, 02:06 PM
Anyone rebuilt their steering gear? Advice?
I am thinking of rebuilding my rebuilding my steering gear. I see lots of kits for pretty cheap compared to the cost of a box with a lifetime warranty and there are quite a few "How-To's" out there. It looks fairly straight forward.
Anyone rebuilt their box? Any special tools needed? Any lessons learned? Any advice?
Old 11-04-2020, 04:33 PM
I rebuilt one several years ago. I think the kit was only $40 but it does take some time. Tip: dont loose any of the roller balls that are in the housing and pack the balls with grease when re-installing. IMO, the only reason to rebuild vs remanufactured is to keep a Large Bore J20 box [because finding a re-man' is like finding Hen's teeth.
Old 11-04-2020, 06:04 PM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
I'm curious how it turns out for you! It seems like the reman'ed units don't last to long, but maybe that's because they weren't set up right.
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
'86 CJ7 Doesn't need anything(so why do I have it?)
Correction- it just needed a water pump!
Old 11-04-2020, 06:39 PM
Yeah, I see rebuilt units starting at $180 and up. Rebuild kits are only $20. If I take about $20 in cleaners and sealants, that is a savings of $140+. Would be worth the time... i think. But if it is a PITA and/or I am going to need a special tool then maybe it is not worth it.
Old 11-04-2020, 06:46 PM
Tripwire's Avatar
Tripwire Tripwire is offline
well you will need a inch pound wrench IIRC to adjust the preload
Abort? Retry? Ignore? >
Old 11-04-2020, 08:23 PM
78 WIDETRAC's Avatar
I just watched a video on rebuild yesterday by Bleepin jeep. The guy was very thorough and had a couple of cool tips for re installing the bearing cage. He used a zip tie after he filled it with ball bearings to hold the halves together and capped the ends off with high temp wheel bearing grease to hold them in. I'll look for it and try to link it here.https://www.google.com/url?sa=t&rct=...0-naCDYH59wZmN
Old 11-06-2020, 11:40 PM
FleetFox FleetFox is offline
Agreed, it's not a high drama rebuild. The vids are good and there are plenty of them. Using the grease to keep the balls in is a great hack. The TSM is helpful as well. Just work on a blanket when you tear it down and segregate the 2 different size ball bearings as they come out. I believe they are 2 different colors black and silver. You can do this.
Fleet Fox
Old 01-13-2021, 06:39 PM
OK, just finished building the Saginaw power steering box from my XJ (same as ours). What a miserable job! Almost everything was seized, getting the piston back in with the new Teflon seals took forever, it was an oily, dirty, gritty, mess. I will never do that again. With the troubles I had, it took me four hours to rebuild that stupid box. Do not go into a job like this thinking it goes as smoothly as the bleepinjeep video shows. It was not worth only saving $100.
Old 01-14-2021, 01:18 PM
Sorry man. Mine was pretty drama free.
Fleet Fox
Old 01-14-2021, 03:12 PM
I sent my steering gearbox to red head steering gear
maybe in Washington state ?
used then on many restorations.....
steering is smooth as silk.
Old 01-15-2021, 12:09 AM
Gotta ask, always do. Did yours have little black balls and little silver balls or all one color? If both did you alternate them?
Old 01-15-2021, 12:42 AM
Talking
Yeah: 2 colors, yep: alternated them. Steering feels good and it is all back together it was just a miserable job. I have talked with 2 people in person and they had the same story as fleet fox: really? It should be super easy and take no time at all... I had no problems.. they said. So it must just be me.
I considered them, SOLSAKS but they were out of my price range this time. Maybe when my daddy Cherokee needs a box it will get a red head.
Power Steering Gear ihatefiberglass General FSJ Tech 9 11-13-2011 06:53 PM
What model S10 donor for steering gear box? Copenhagen1 Suspension and Steering 23 12-04-2009 02:30 AM
Steering Gear Swap Question utvolsfan General FSJ Tech 15 08-20-2009 06:02 AM
727 UPGRADES J10-401 General FSJ Tech 18 02-13-2007 08:21 AM
Need some help with steering gear specs bigblack'74 General FSJ Tech 2 04-13-2004 05:04 AM
