Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Wanted
Old 08-17-2022, 05:15 PM
Cherokeeowner's Avatar
Cherokeeowner Cherokeeowner is offline
Emissions hose needed for GW
I'm looking for the air pump hose on my 88 GW. Anyone have one laying around?
"Proud to be prissy."
1988 Grand Wagoneer
1986 Grand Wagoneer
Old 08-17-2022, 06:34 PM
devildog80's Avatar
devildog80 devildog80 is offline
You can use a straight piece of tubing, some semi rigid metal tubing pieces with the bends you need made then inserted into the tubing, and have the same layout as the factory made tubing.
Or repair the split portion with a curved piece of metal tubing that would fit snug inside, and seal the split section.
'81 CJ5 Base, 258 I6, MC2100, T176 4 spd, 300 TC, D30 Front NT, 3.31, 2-Piece AMC 20 rear NT, 3.31, 4" high arc spring lift
'84 Grand Wagoneer, 401 V8 (.030 over), MC2150 HA Comp, 727 auto, Selec-trac NP229, AMC 20 REAR - D44 FRONT - WT 3.31, 4" high arc spring lift
Rather be driving, than waiting to be modified
Old 09-04-2022, 11:56 AM
Cliff's Avatar
Cliff Cliff is offline
I have one from a 77. Send me the length and inside diameter of yours and I will see if it's the same.
Cliff Danley
1977 Cherokee S
Old 09-04-2022, 12:06 PM
Or get some large heat shrink tube for electrical work and install it over the cracked area?
Old 09-07-2022, 06:51 PM
Thanks Cliff, I will measure it up and post the measurements.
1988 Grand Wagoneer
1986 Grand Wagoneer
Old 09-13-2022, 07:22 PM
Cliff, the hose is a foot long and the openings on both ends are about 3/4 of an inch.
1988 Grand Wagoneer
1986 Grand Wagoneer
Old 09-14-2022, 06:22 PM
Cliff's Avatar
Mine is a full 24 inches, and the hose ends are 3/4 and 9/16. I'm surprised they are so different.
Cliff Danley
1977 Cherokee S
Old 09-15-2022, 04:37 PM
Is it on 360? Mine is.
1988 Grand Wagoneer
1986 Grand Wagoneer
Old 09-17-2022, 01:02 PM
Cliff's Avatar
Mine came off a 401
Cliff Danley
1977 Cherokee S
J10 Lower radiator hose 360V8 Oolah10293 General FSJ Tech 15 05-02-2014 02:26 PM
73 Heater Hose Tee's off to Engine Block???? The Grand Pooh-Bah General FSJ Tech 10 06-06-2013 07:09 AM
The Emission vs. Mileage vs. Power... Tinkerjeep General FSJ Tech 103 02-24-2013 01:36 PM
Emissions equipment on GW - same all years? Scramblin_Jim General FSJ Discussion 3 04-21-2007 07:12 PM
Emissions? Laws? Mike Z General FSJ Tech 7 01-13-2001 11:39 AM
