Old 08-09-2022, 04:52 AM
delfuegosr's Avatar
delfuegosr delfuegosr is offline
E-Brake/ Parking pedal assembly for 1973 Pickup
Question for the experts - I have a 1973 J2500 Pickup and my E-brake assembly is wore out and will not hold pedal tension. It has the lift up release handle and not the modern pull to release sytle handle. Will the newer style pedal or some other E-Brake pedal assembly bolt up to my truck without modification? Two (2) bolts on firewall and two (2) bolts into dash frame. Has anyone replaced the 1973 and older style E-Brake assembly with a newer style. What fits? Thanks in advance!
Old 08-17-2022, 05:18 AM
Well, I have never swapped parts but I could check the mounting pattern against each type to see if there is a noticeable difference.
Resistance is not futile yet.
Old 08-17-2022, 11:01 AM
These pedals were very unreliable in the early '70s Jeeps, and they went through several revisions. I handled a lot of bad ones as warranty parts. Often they would bend, and this moves the ratchet sideways from the pedal teeth. Sometimes they can be straightened and work again.
JMO - look for a later pedal that you can make work. You might find a replacement in a junkyard FSJ, or in the parts listings here or at fsjnetwork. The Wrangler used a pedal of that type, and you may be able to adapt it. There are lots of listings for used Wrangler pedals, with good pictures. Not cheap though. If you can weld, you can modify the mounting bolt locations so the newer pedal will fit in place of the older.
Old 08-19-2022, 03:48 AM
Heep-J4000's Avatar
Replace it for some kind of pull parking brake lever!
They are way more reliable than the foot pedal park brake.
73' Jeep J4000 (named Heep or Desert Dragon) amc 360 V8 converted to LPG with T15/D20 (was my daily work truck for thirteen years and is getting major overhaul at the moment!)
80' Jeep cj5 350 V8 Chevy/sm420/D300 project
70/71 Jeep J4000 parts truck with Buick 350
Former vehicles:
Old 08-21-2022, 11:02 AM
delfuegosr's Avatar
Thanks for the suggesstions! I'll look into a replacement.
Old 08-21-2022, 12:08 PM
devildog80's Avatar
devildog80 devildog80 is offline
Check these out
https://lokar.com/ebrakes.html
'81 CJ5 Base, 258 I6, MC2100, T176 4 spd, 300 TC, D30 Front NT, 3.31, 2-Piece AMC 20 rear NT, 3.31, 4" high arc spring lift
'84 Grand Wagoneer, 401 V8 (.030 over), MC2150 HA Comp, 727 auto, Selec-trac NP229, AMC 20 REAR - D44 FRONT - WT 3.31, 4" high arc spring lift
Rather be driving, than waiting to be modified
"Emergency" Parking brake issue..? Wagoneer-ing General FSJ Tech 8 08-27-2013 06:33 PM
Still need some brake help....slow pedal return. Dr. Marneaus General FSJ Tech 56 07-05-2013 11:47 AM
Brake pedal - height adjustment? iroc86 General FSJ Tech 3 07-30-2009 10:05 PM
Parking brake woes spark691 General FSJ Tech 11 05-07-2009 02:44 PM
parking brake switch/dome light question Steelhead General FSJ Tech 3 03-14-2005 03:58 AM
