Old 08-03-2022, 07:47 AM
mark's Avatar
mark mark is offline
front blinker assembly removal 76 chief
i have the lenses out down to the bulb.can i pull the whole housing out from the front somehow?
i dont see the clips on the side at all like the newer ones.
i was hoping to do this easily without a lot of disassembly.
mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> [IMG]<br />[url=http://www.fsjworld.com/mygallery.ten?id=3481[/URL]<br />[/IMG]
Old 08-03-2022, 07:56 AM
cu4whln's Avatar
cu4whln cu4whln is offline
It snaps in,
There are two tabs, at each end.
Use a screwdriver and CAREFULLY bend one side in and it should pull out.
Just be careful not to break the tab off.
Good Luck!
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver - 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Old 08-03-2022, 08:35 AM
mark's Avatar
from the back?
i cant seem to see anyything with sheetmetal in the way.
Old 08-03-2022, 08:52 AM
78 WIDETRAC's Avatar
Originally Posted by mark
from the back?
The tabs he is talking about are on each vertical side of the plastic housing accessed from the front, after you remove the plastic turn signal lens. they are very brittle in most cases.
That is all that held them in from the factory.
Old 08-03-2022, 11:34 AM
mark's Avatar
mine is not plastic.
i see tabs on pix of the plastic ones.
mine is potmetal and looks different
Old 08-03-2022, 01:50 PM
early style have total pita metal clips that must be released from backside.
Old 08-03-2022, 02:16 PM
mark's Avatar
i got it out.took 2 of us and had heavy metal clips that needed to be pushed in from the back while i pried from the front.
the good news is that i got 2 1/2 inch wrenches and a 3/8 extension out of it!
Old 08-03-2022, 10:44 PM
Sorry for my misinformation. I didn't realize metal housings were still being used into the mid 70's. Great news on some bits for the tool box.
Cherokee chief front ends Rangerrandy90650 General FSJ Discussion 7 03-29-2015 01:48 AM
Front D44 Yoke Removal Schlagger General FSJ Tech 7 09-16-2011 03:13 PM
Removing Blinker on Rhino Front AZRetiredCPO General FSJ Tech 4 02-28-2010 08:30 PM
Tearing down the 79 Chief... First engine removal.. Dmntxn77 General FSJ Discussion 3 12-08-2007 01:57 PM
front disc removal manual hubs J10Joe General FSJ Tech 17 12-19-2005 04:21 AM
