I rebuild my entire front axle about 1000 miles ago. I put bigger ebc brakes and calipers on as well as all new bearings, seals, and spindles. On trips longer then 25-30 ish miles I am realizing my front wheels are getting hot. I can hold my hand on it for a second or two but not much longer. The rear wheels are relatively cool to the touch.
Whats the best way to figure out if the bearings have an issue here and are causing the heat?
I have noticed if I lift off the gas the truck slows down more so then it should. So maybe it's more of a brake thing. I'll pull apart and re grease caliper pins.
