Sigh.... I hate trying to figure this kind of stuff out. I like what's broke to be obvious. Here are my symptoms, any suggestions are greatly appriciated!
runs rough/misses at idle - worse when cold. Stalls occasionaly and then sometimes won't start! Gets flooded easily I think. Usually starts fine.
plugs/wires/cap/rotor not new but look fairly good. Coil looks old.
couldn't find any vacuum leaks with 1/2 a can of starting fluid.
Carb doesn't look like it's ever had a rebuild.
Start with rebuilding the carb? Replace the coil? New plugs and all the rest? If you need to know anything else to give me an idea what to try just let me know!
Thanks in advance!
Thanks in advance!
