Old 07-14-2008, 11:37 AM
Heimeken's Avatar
Heimeken Heimeken is offline
Exclamation Help!!!! Need part number for M715 replacement Radiator
A couple of FSJeepers are stuck in Red River NM, with a broken radiator on the M715. They need a part number for a replacement radiator that will fit int the stock position. Catch is that is truck has a Chevy 350 in it. Anybody got a part number?
Thanks
401, NV4500, 3/4 ton gear
'79 Cherokee "The Sandgorgon"
One Tons, SOA,T18 on 40's
78 J10 "Imoteb"
J20 running gear and axles
Old 07-14-2008, 12:12 PM
HOOT's Avatar
HOOT HOOT is offline
I would try and post over at M715 Zone.
My catalogs don't cover those. Being a Chevy conversion makes the books even more useless. I'm sure someone over there has a Chevy in theirs.
People need to bypass NM on the way to Ouray. Bad things happen in that state.
Tom Gibson
1980 J20 Utility bed truck. Factory cab and chassis truck. Many new mods for it but it will look all stock.
1985 J10 nothing special just a nice clean stock truck.
2017 Challenger. Very jealous of the Jeeps.
Old 07-14-2008, 12:22 PM
Heimeken's Avatar
I think I found it, modine 289 or 433289.
Darnit, I have to pass through New Mexico every year
78 J10 "Imoteb"
Old 07-14-2008, 12:43 PM
HOOT's Avatar
OK so you make it through NM OK every year.
Maybe the problem is J Trucks in NM.
I like to know how many times he asks himself why he bothers with Ouray. Hang in there, you made it further than me this year.
What doesn't show in the thumbnail is the shattered transfercase, bent drive shaft, broken springs,crushed Thorleys,sheared brakelines, and numerous other stuff.
Tom Gibson
Old 07-14-2008, 01:24 PM
Brad W.'s Avatar
Brad W. Brad W. is offline
the CJ-5 chevy conversion radiatiors should fit, pretty sure some guys have used those. not sure on the P/N, sorry.
Brad W.
1979 wag "Nightmare"
**project shelved indefinetly**
m715 ex-firetruck
**project shelved**
2001 Dodge Ram 2500 "Project Juggernaut"
24v-CTD/NV-4500/quad-cab/4x4
4" straightpipe, rollin on beadlocked 37's.
Old 07-14-2008, 09:55 PM
robert cowan robert cowan is offline
RAD.
I,VE GOT SOME NEW OLD STOCK RADIATORS FOR THE M715 AND AFTERMARKET ALUMINUM RADS. FOR EM TOO.
BOB
1 423 384 8938
I BELIEVE IN JOHN 3:16
Old 07-14-2008, 11:21 PM
TPICherokee's Avatar
CCCCCCAAAAAAAAAPPPPPPPPSSSSSSSSS LLLLLLLOOOOOOOOOOCCCCCCCCKKKKKKKK.
It is a button on the left of your keyboard...
Old 07-15-2008, 07:58 AM
JeepBountyHunter's Avatar
GrimJeeperReaper
Just curious, but with a Chevy, would the top hose go to the opposite side of the radiator than the original configuration?
2005 Mustang Convertible...meh....
Too many hobbies! $$$
Old 07-15-2008, 08:13 AM
FSJ Guy FSJ Guy is offline
The other issue is which radiator support they have. The stock rad support is different than the civilian support.
I hope they got the issue resolved.
Ethan Brady
www.bigscaryjeep.com
Old 07-15-2008, 09:34 AM
What wasn't said by Jaime was that the reason they need a new radiator was they damaged their's by shoving it into the fan during a stream crossing!
The last I had heard Jaime had found one and was taking it to them, they were hoping to get it around 10PM last night
Old 07-15-2008, 10:30 AM
HOOT's Avatar
I finally Googled it to see where Red River was. Sure enough it is part of the Enchanted Circle. I never want to see that place again.
My trouble started in just as I got near the Circle. Spent a few days there trying to get out. I will admit that canyon drive was cool, just eerie now. I left the same way I went in.
Frank should be coming up below them today also.
So are they doing the Rio Grande trail across Stoney Pass?.. That was the most spectacular ride of all.
Tom Gibson
Old 07-15-2008, 10:43 AM
I don't know I have only had short talks with Kenny while trying to figure out what they needed and letting them know that Craig didn't have one in his stash,even if he did there would have been no way for him to bring it since they are "gag" coming up in a liberty!
