Old 10-25-2007, 07:10 AM
mtnbikerman mtnbikerman is offline
High Idle No heater and buzzer
I was looking under the dash last night trying to fixed the defroster flapper and pulled the only vacuum hose I could find connected to a white motor looking thing on the driver fenderwell. Anyways after I pulled this line the engine idled high, the wipers quit working, the headlight buzzer goes off with the engine running, and the heater fan doesnt work anymore?
Could it be a fuse or what?
There's no smog stuff or vacuum other than the advance from the distributor to the carb
The heater controls and wipers. The washer fluid doesn't work either but never has before this
the 229 was swapped for a 208
83 Wagoneer 360 727 NP208
Old 10-25-2007, 08:40 AM
J4GRAND's Avatar
J4GRAND J4GRAND is offline
J4000 Restoration Specialist
Pulling a vacuum hose would have nothing to do with the wipers quitting and the headlight buzzer buzzing. I think you knocked a few wires loose. As for the vacuum line, hook it back up and see what happens.
Patrick V.
MEMBER #14
78 Cherokee Chief WT "Old Blue" 360 V8 4V TH400 QT
05 Jeep Grand Cherokee 3.7 V6 5 speed automatic with new QT
Old 10-25-2007, 09:29 PM
Ok I think I figured it out
Ignition switch is shorting out
It will actually lock up and I couldn't get the
thing turned off.
it seems to be the key switch
Is it hard to replace the ignition switch?
Old 10-26-2007, 06:57 AM
Sorry used the wrong words
Would it be the ignition switch or the lock cylinder?
IF i move the key back and forth a little in the on position
I can make the heater fan, the wipers, and the radio, lighter
all stop for some reason the buzzer comes on.
So would that be the cylinder or the switch?
Also too the cylinder/key got stuck on and I couldn't get
the jeep shutdown for like 5 minutes till I fiddled around enough
to get it to shutoff For some reason the Edlebrock carb gets stuck in
a fast idle when this happens too but I don't know if thats related
I can pull the key out of the cylinder with it on too but
that happened to an old chevy I had never affected it like this jeep.
Old 10-26-2007, 07:43 AM
J4GRAND's Avatar
That sounds more like the ignition switch on the top of the column under the dash then the tumbler. Ther's not much that can go wrong in the key switch. If moving the key affects the electrical then the ignition switch is most likely the culprit.
Patrick V.
MEMBER #14
Old 10-26-2007, 10:34 AM
BarnOwl BarnOwl is offline
Banned
Maybe ncjeepers can help out on this one. He is pretty good with these kinds of malfunctions.
Old 10-29-2007, 06:11 AM
Now ignition is stuck on
Ok now the ignition is stuck in the on position its locked there I can't get it to budge I can pull the key out but the cylinder is stuck in the on position but I can start it at least and drive it I just have to pull the coil. Any suggestions?
Old 10-29-2007, 09:38 AM
Banned
Forget about the bad ignition.
Let it run, but keep putting gas in it every few minutes or so. That way, it will always be warmed-up and ready to go!
Old 10-30-2007, 06:04 AM
Ok now I got the cylinder moving again but
it won't start now. I guess I'll just have to break it down.
Old 10-30-2007, 10:49 AM
Banned
Sounds like it's already broke-down. Maybe you need to build it up.
