  #181
Old 05-23-2020, 02:47 PM
wincher's Avatar
wincher wincher is offline
which oil do you use for the diffs?
GL5 is a must?
We have a mobillube (141064) gx 80W90 in stock, but this is only API GL4
and a GL5 hich is used in the diffs of the Merceds benz Unimog, but this is not a 80w90
78 chief 360amc
02 wj 4.7HO Overland
Old 05-23-2020, 03:45 PM
you should be fine with regular 80-90w oil.
Old 05-24-2020, 04:54 AM
wincher's Avatar
I have used the 75W90 GL5 and not a GL4
78 chief 360amc
Old 05-24-2020, 04:58 AM
wincher's Avatar
How is your ignition system? a weak spark can cause this also.
Whats about a non return valve in the fuel hose?
After a longer stillstand the engine starts and dies.
Than i have to do some seconds with the starter for restart.
After a short stillstand it starts directly
78 chief 360amc
Old 05-24-2020, 07:32 AM
wincher's Avatar
Today pics of the sparks from piston 1 and 3 with the 75x47 rods and 95 MJ
The isolator is now more bright and tan.
runs better than before.
bogs only with full throttle after rolling in idle and or low revs.
from 40 mph i can "normal" speed up.
sometimes he is spitting a little...
it is hard to explain that in words...
(The oily tip at the last pic is from touching the engine .. it is still oily from the cover seal.. )
https://i.imgur.com/sEJgjG8l.jpg?1
78 chief 360amc
Old 05-24-2020, 07:34 AM
If it sits for awhile the fuel will evaporate in the carb, especially in warmer times. a electric fuel pump will help with that, it will prime the carb with fuel so it should take less time to fire it up. Also install a plastic insulator spacer between the carb and intake manifold, to help keep the gas from boiling out.
Old 05-24-2020, 07:37 AM
wincher's Avatar
This is now my electrical modification.
Ammeter out of function.
100A circuit breaker for the alternator
30A screwable fuse for the dashboard, light switch, igniton switch
flying fuse for the e choke
78 chief 360amc
Old 05-24-2020, 07:43 AM
wincher's Avatar
I will add a 12V socket outlet in the rear trunk for a cooler box and transfer the wire under the carpet.
should i use the wire 50 from the A/C compressor (A/C is out)?
Any better idea?
78 chief 360amc
Old 05-24-2020, 07:49 AM
wincher's Avatar
ok. the chief was the night out and we have only about 50
I hope the warmer times come soon!
A old pic from the preowner.... but you can see it is a thicker rubber sealing mounted.
Maybe the edelbrock heat insulator gasket 9265?
Have added a new paper gasket between this and the carburettor.
78 chief 360amc
Old 05-24-2020, 08:23 AM
wincher's Avatar
And now back to the old topic with my gauges.
Remember:
I have installed a new 5V CVR in my instrument panel
in the same way new sender for temp and oil pressure.
Dash connector was out and all wires checked.
fuel gauge works, i hope correct (have it not filled the tank total full but i have spend 25 l and the gauge goes to 3/4 )
oil pressure between 25-20psi , goes to 0psi when hot.
Probably no electical reason
I have still no temp gauge. Gauge is totally on COLD
When do the sender wire on ground the gauge goes to HOT.
After about 3 miles i did this measurement:
Engine not running
A1,A2,A3 = 5V (CVR works)
A1 (oil) = 3,73 V on the gauge to ground and on the sender wire to ground (wire is ok, but only 3,73V??)
A2 (Fuel) 2,4V (Tank is a litte more than half full)
S3 (temp) 3.33V at the gauge and the sender unit to ground (wire is ok)
(But only 3,33V? a few days ago i had 4,73V)
Resistance from the (new) sender to battery ground: 25,1 ohm
like the specification in the pic this might be right and the sender is still ok
but sometimes i cant measure any ohmic resistance!
Have tried a second multimeter too.
And i have different ohmic data on the gauge.
I am on the end of my tether
78 chief 360amc
Old 05-24-2020, 09:23 AM
You need to use a 1 inch plastic spacer under the carb, (edelbrock is fine) You probably have a bad sensor for the temp gauge.
Old 05-30-2020, 01:33 PM
wincher's Avatar
I have now a new Sender for the Temp. The Second
It is the same. Temp stays at cold
Something must be wrong with the Gauge or the CVR in the Gauge..
today temp gauge resistance
S to ground 3,7 ohms (instead 36 to 72)
S to A 18,8 Ohms (19 to 21)
A to ground 21 ohms (instead of 49 to51)
in my view the temp gauge has a technical fault.
78 chief 360amc
Old 06-09-2020, 07:02 PM
That's what it looks like to me, too. (Fault in the gauge). I say let it ride for now. Focus on getting the carb tuned. You know you are not overheating so table it for now.
Old 06-13-2020, 07:29 AM
wincher's Avatar
Haha! Today After a few Miles. Was at home and playing with the shift Lever again...
(Have to adjust the neutral Switch.... Engine Start Not at P. Have to Shift a little to R to get the starter turn around)
But a wonder: Temp Gauge goes to the green area!
A sign of life!
Later the few miles back to the Garage the Gauge stays still at totally cold again..
78 chief 360amc
Old 06-16-2020, 05:27 PM
Hm... Do you have a good ground from your engine to the body/frame? Maybe ground the wire at the sender and check resistance to make sure all your connections are good and not corroded?
Old 07-07-2020, 12:06 PM
wincher's Avatar
It is the same redistance only through the sender as through the sender and to the Battery ground
78 chief 360amc
Old 07-09-2020, 07:00 PM
letank's Avatar
letank letank is offline
Originally Posted by wincher
My "new" board.
Did the 5 V part as you can see on the heater board.
ground them on the heater ground (white wire)
12 V comes from the pin 15 (I)
the radio noise suppressor is ok,
the 5 V are for the A3 and A2.
The conductor path to A1 is ok.
Unfortunately I have not tested al with the multimeter...
Now I have
no oil pressure
no fuel
temp is full hot
May be your temp gauge is fried inside, check these posts, and even with the CVR, it might not connect to the gauge
https://www.fsjnetwork.com/forum/vie...=8334&start=20
or measure the resistance given by the sender between the battery ground and the sender terminal, 73 ohm when cold, 36 at beginning of band and 25 ohm when warm 10 miles of driving... or close to these values, as labelled in the TSM
Michel
Old 07-12-2020, 06:37 AM
wincher's Avatar
Hi,
this is not the current status.
Fuel and oil pressure works, Temp not or only a little
have changed the temp sender to times.
Sender ok. 5 V from new CVR to sender ok. Resistance from sender ot ground/Battery ok. I think the gauge is the failure.
The failure
78 chief 360amc
Old 08-27-2020, 01:46 PM
wincher's Avatar
Front Driveshaft
I will order a 4" lift kit from rustys to level my chief.
Is a longer driveshaft neccesary and how to get one?
I know from the lift kits for the WJ grand cherokees with homokinetik driveshafts from the ZJ or JK are made to fit.
rims
I have used 33s tires but not a second set of rims, and will not dismantle the 31s from the rims.
My rims are steel chrome, looks like the cragar chrome nomad 2 from summit (8 spoke)
Which rims was original on the chiefs?
only the white 8 spoke rims i have seen on many pictures?
can buy from a friend rally rims, but sandblasting and powder coating is a must (they are purple)
I think black was not a color of the 70s and not fittable. the car must be mostly original for the historic car licence in germany.
78 chief 360amc
Old 08-30-2020, 04:49 AM
wincher's Avatar
AEM oxygen sensor
today a rainy sunday morning.
Time to install the oxygen sensor.
First impression - the way home.
idles with 11,9 to 12,5
fuel cutoff was about 16, but not a high rpm(50-55mp/h)
WOT in green area. have to test it again.
is it right to adjust the idle mixture screws to 14,7AFR?
(AEM manual says WOT10,5 - Idle/Cruise 14,7
- cutoff 20,0)
78 chief 360amc
76 Chief 360/auto bolt into an 80 J10? FMSINC General FSJ Tech 14 02-17-2016 04:05 PM
1979 Jeep Cherokee Chief backfires Brody93 General FSJ Tech 9 01-23-2012 09:37 PM
4.0 swap in a 1979 Chief Pullie General FSJ Tech 25 10-28-2011 06:51 AM
Difference between chief and chief "s"? rentalrider General FSJ Discussion 2 04-22-2011 03:33 PM
1979 Baby blue Chief...SAW YOU TODAY! PlasticBoob General FSJ Discussion 0 04-17-2008 08:45 PM
