Old 02-17-2014, 11:20 AM
vacaisle's Avatar
vacaisle vacaisle is offline
snide. snarky. grease covered.
Exhaust damper/heat riser gasket or no gasket
I reinstalled the exhaust damper after machining the damper to manifold surface of the damper flat but I'm still getting an exhaust leak there. Do I need a gasket or does the manifold also need to be machined where it meets the exhaust damper?
89 Grand Wagoneer
145,000 miles, TFI, MSD 6a
Old 02-17-2014, 12:01 PM
yes. gasket.
Old 02-17-2014, 12:23 PM
Coondawg Coondawg is offline
I always had trouble finding the gasket at the parts house. I ended up taking the whole damper and finding one that fit. 1983 Ford ranger 2.8l flange gasket is what I think I ended up using.
Old 02-17-2014, 01:22 PM
vacaisle's Avatar
Is it best to use the steel kind like BJ's sells or the composite material kind?
89 Grand Wagoneer
Old 02-17-2014, 01:58 PM
metal. copper.
Old 02-17-2014, 02:50 PM
vacaisle's Avatar
This'll work right?
http://www.ebay.com/itm/Crown-Automo...e1b64e&vxp=mtr
89 Grand Wagoneer
Old 02-17-2014, 03:40 PM
yes,providing it's the correct size.
Old 02-17-2014, 03:50 PM
vacaisle's Avatar
I just searched the part number (J5353073) and it came up AMC 360. Found it here: http://www.quadratec.com/products/51100_1011.htm
89 Grand Wagoneer
Old 02-17-2014, 10:56 PM
Tinkerjeep's Avatar
Banned
Yeh. gaskets.
Old 02-17-2014, 11:13 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
Slather some Copper Coat sealant on those gaskets if you want some extra insurance against future leaks.
If you're like me, you hate exhaust leaks because they make your car sound like a beat up pile of junk.
Old 02-17-2014, 11:24 PM
Tinkerjeep's Avatar
Banned
I'm like you in that department.
Old 02-17-2014, 11:27 PM
FSJunkie's Avatar
Cool.
Old 02-18-2014, 12:11 AM
vacaisle's Avatar
I feel the same. I'll try that. Mine may look like a pice of junk but it doesn't run like one.
89 Grand Wagoneer
Old 02-23-2014, 02:07 PM
vacaisle's Avatar
Crown 5353073 worked perfect. Now I can hear my valve train noises more clearly!
89 Grand Wagoneer
Old 02-25-2014, 05:25 PM
Banchee's Avatar
Banchee Banchee is offline
In case anyone ever needs a new heat riser valve I have some NOS Jeep heat riser valves that include the flat gasket being talked about here.
NOS factory Jeep heat riser valve with flat gasket $45.00 shipped priority US-48.
91 XJ Cherokee Limited
99 Dodge Ram V10 4X4 (This thing will pull a house, but won't pass a gas station)
2010 Grand Cherokee (Hemi)
2014 Dodge Avenger SRT6 Blacktop
Question about replacing exhaust manifold. Gasket or no gasket? charlie500 General FSJ Tech 15 06-03-2012 11:02 AM
Busted exhaust manifold (FIXED!) Heat Riser? M1Garandfan General FSJ Tech 5 03-17-2004 01:57 PM
Changed passenger side exhaust manifold gasket jeepthing General FSJ Tech 2 06-20-2003 12:50 PM
"an exhaust system can also be too efficient." Jerk General FSJ Tech 25 09-12-2002 03:58 PM
Stock exhaust manifold gasket??? thos General FSJ Tech 4 05-22-2002 05:21 AM
