Old 06-16-2011, 02:01 PM
Pullie's Avatar
Pullie Pullie is offline
4.0 swap in a 1979 Chief
last week I started the swap to a 4.0 out of a 1998 Grand Cherokee.
Brake booster is a YJ
Axles are Nissan Patrol
engine is offset 1,25" to allow clearance for brake booster
Some pictures:
twinsticked D300 to be installed
space between intake and brake booster
clearance between pumpkin and engine
tack welded engine mount, will be fully TIG welded
engine at full bump and 35" BFG MT tires
might have to lower the car a little bit, or install 37"
tomorrow will be test fitting the front clip and hood to see if all the additional stuff will fit (radiator/ battery and stuff)
hopefully the build will be starting to get going a little bit
Old 06-16-2011, 02:06 PM
Interesting. The 4.0L is a great engine - you should be very happy with the result.
I thought I misread the "Nissan Patrol" axles, then I noticed your location. Here in the USA, Patrols are really rare, having been imported for only a couple of years, and in low numbers, in the late '60s. Apparently they are not so rare over there.
Old 06-16-2011, 02:20 PM
gguido gguido is offline
Yo Paul,
Looks great! When are you planning to get it started?
When the moment is there, let me know!
The J10 is making progress, soon I will be driving your street!
groeten uit Deventer
Guido
Old 06-18-2011, 02:17 AM
Pullie's Avatar
Easily available, 4.88 ratio, air locker big disc brakes and almost as strong as a ford 9 inch looked like a winner.
Not sure on the 42re but if it wont hold i'll get an aw4
Old 06-18-2011, 08:27 AM
That is looking great, subscribed to watch your progress...
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 06-20-2011, 12:54 PM
Pullie's Avatar
Last weekend I/We dis some testfitting of the panels to check for clearances and stuff. also put the front springs in te check ride height.
Looks like I won't be needing a BL or a Hydroboost, altough the latter might be necessary depending on how she'll brake with the YJ MC.
anywaay, here are the pictures :-)
at rideheight on 35" 4" bump at the moment, might increase to 6 or just add the 37's
front spring, it's a shorty but I'm not looking for flex (hence the radius arms) but for zombie smashing comfort
clearance between engine and radiator, might do electric fan, not sure yet
drivers side clearances
passenger side clearance
placed the PCM
plans for coming weeks:
- take out the front end and fininh welding/mounting the motor mounts.
- build a tranny mount
- placing the 1998 GC tank in the spare tire location, might be a tight fit measured a 1/4 clearence
but first a 10 day vacation to take the family out
Old 06-20-2011, 01:38 PM
Eric S. Eric S. is offline
Very nice build! You're going to have a very unique ride in Holland. The Zombies will be very confused before you run them over.
If you get some free time, put the rest of that Patrol in a box, and ship it to me!
1989 Grand Wagoneer -- FOR SALE
Old 06-20-2011, 01:39 PM
austinaubinoe's Avatar
Looks awesome! You didnt use the crappy grand cherokee tranny did you?
I dont really understand how you got so much lift from such tiny springs?
Old 06-20-2011, 01:56 PM
Pullie's Avatar
only got the axles, same price here as the D44 with 3.54 en drums. complete patrols here go for between 1500-3500 dollar, usually with 250.000 miles tough.
austinaubinoe, I did put the crappy 42RE in, is it dies I'll look for a OBD2 AW4.
at the moment with the availability of parts and conversion parts very limited (you only find small VW's here in junkyards) it's the easier choise since it will make initial wiring and stuff easyer.
Basically I'm using 1998 GC driveline with D300 instead of NP249 and the GC wiring/gauges and the fuel system. seems like the easyest way for a OBD2 swap.
I think that the lift comes from the low frame mountning point (frame centerline height) I might move the top coil holder up a little bit, altough the height keeps growing on the wife's ease of mind so I just might be able to simply "forget" to lower it
Old 06-20-2011, 03:06 PM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
Looks like you are having lots of fun
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 07-02-2011, 02:05 PM
Pullie's Avatar
came back from vacation today, started mounting the tank. would like to have about 20 gallons of gas and 25 gallons of LPG.
fit the grand cherokee tank in the back. still contemplating on doing a bodylift just to be able to get the tank in higher, at the moment the tank is 21 inches from the floor on ride hight.
Also gonna redesign the front frame side coil buckets. I want them higher to drop the ride height and adjustable to be able to fit bigger tires.
here some pics from the gas tank:
that's it for today, have a whole week of thinking and tinkering coming up
Old 07-02-2011, 02:29 PM
Here's my 84 J10 with 4.0L/AW4 on Photobucket I've been working on the past 10 years off and on (mostly off due to health issues)
See the fullsize version at: http://s6.photobucket.com/albums/y20..._ media_share
I still have a full set of factory I-6 frame horns, mounts from the motor and Energy Suspension poly mounts. GM Hydroboost is easier to do than other brand braking.
Old 07-03-2011, 06:57 AM
sld's Avatar
sld sld is offline
Hope that this isn't too late, in the next to last photo, I noticed your tape measure is out of calibration . Didn't want you to mess up all of your measurements.
Old 07-03-2011, 01:02 PM
Pullie's Avatar
Luckily all my measurements are off by factor 2,54
Was actually searching before the pic to loacate a measuringtape that displays inches and centimeters...
Old 07-04-2011, 08:17 AM
grand_wag_85's Avatar
Murphy's Law Poster Child
I LOVE your motor mounts, very nice!
'65 J2000
Old 07-04-2011, 01:55 PM
Pullie's Avatar
Did some stuff today.
- Cleaned out the garage
- traded the old Grand cherokee bumpers for 2 cases of beer
- pulled the front bodywork
- finished TIG welding the Right motor mount
Tomorrow I'm gonna try to redesign the left motormount to make room for the steering shaft.
Old 07-04-2011, 02:03 PM
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 07-11-2011, 01:27 PM
Pullie's Avatar
tomorrow turned into next week
but I got it done, now there is room for the steering shaft and some other stuff that might need to get in there.
Pics of driver side motor mount:
also started redoing the frame side coil spring mount.
I wanted to use longer springs and drop the ride height a little bit.
some pics of mocking up the new mount.
keep gtiing better with the TIG welding.
Old mount:
General stance now.
this week I'm gonna try to finish the coil spring mounts and try starting on the tranny mount.
Old 08-22-2011, 01:14 PM
Pullie's Avatar
Last week I lifted the body off the frame. and finished welding the suspention brackets.
also had some "quality time" with the wire wheel.
I'm only able to clean and paint the front half of the chassis since the garage is not long enough for the body and the chassis, hope to have some paint on her next week.
paar avonden bezig geweest om alle nieuwe steunen van de ophanging af te lassen.
BTW, is it posible to change the thread title? It's starting to look more like project than just a 4.0 swap.
would like: "1979 Cherokee Project"
Old 09-22-2011, 02:29 PM
Pullie's Avatar
did some more stuff last few weeks:
Started out the exhaust, it's 2,25" Stainless 304 Still waiting on a magnaflow cat and muffler to finish it.
Finally got the D300 adapter from novak. My wife opened the box as I was gone for work and she knew how much I had payed for it, she was dissapointed with it, (should have been shinyer )
Cleaned all the brackets of the H233B and fabbed up some spring perches and tacked them on:
scored a free Warn M8000 winch from work last week, it was on a truck on wich the lease contract expired so I could have it if I took it off.
Made a fuel tank mount / skidplate
And I painted the rest of the frame:
Hopefully next few weeks I can finish the frame / exhaust / rear axle and fuel system
Paul
1979 Cherokee WT 4.0/42RE/D300/H233B with 4.88 and rear locker/35x12,5x15 BFG MT
Build still in progress:
http://www.ifsja.org/forums/vb/showthread.php?t=142161
isuzu axle swap flatlander58 General FSJ Tech 9 12-15-2009 10:28 PM
1979 Wagoneer with Quadratrac Swap Question TKulak Off-Road FSJ Tech 4 02-22-2009 08:43 PM
360/304 V8 Head Swap Questions - Hi comp / low comp, etc! Greg Taylor General FSJ Tech 10 01-14-2008 07:55 PM
