**** 05/27/2009 EDIT ****
Elliott recommended that I edit this first post with a need/want list for the buildup, so that we can see what's covered and what's not, and who has donated parts so far. See way below in the next **** section for the list, including the "christmas wish list" stuff.
Hey guys,
A very cool guy and long time member on the FSJ-List (who wants to remain anonymous) donated his nice '87 GW to my buddy Tim, who is a missionary in Guatemala (Central America just south of Mexico.
The GW is in nice shape and only needs the rockers replaced (new ones were included!) and the rear quarters patched up ... all which will be done in Guatemala, once it's down there (body work is rediculously cheap in Guate).
It currently has a tad over 100,000 on the odometer, with a remanned 360 from another Jeep installed, which runs fine, other than the 2-bbl Holley giving fits at cold-start with the choke settings.
It sports a 3" lift and 31" Perelli tires. Other than that, it's stock. 360 V8, 727 auto and NP229 t-case. I don't know if it has a rear Trac-lok or not.
My buddy Tim currently has a Dodge Dakota in Guatemala, which is getting the SNOT beat out of it, on the mountain "roads" which he has to travel to get to some pretty remote mountain villages. Driving in Guatemala's mountains is well ... more like serious offroading ... sometimes the paved roads even become CRAZY really fast, due to rain storms washing out hugh sections of roads, which don't get repaired for weeks or months.
Suffice to say, we want to build up Tim's new GW so that it is READY for the trip down and it's new life off-roading thru Guatemala. So, I'm starting this thread to get input and build interest in the project.
We need your tried-n-true expertise in building up this GW to last. We already know from seeing how the Dakota (2" body lift and 31" tires) is getting beat up bad, that we need to higher ground clearance with the GW to clear some of the rocks Tim will be dealing with on the mountain "roads".
Here are some of the ideas we have been tossing around ...
1) 6" lift
2) 2" body lift
3) 33-35" tires (currently has F/R Dana 44's 3.31 gears)
4) Holley Street Dominator intake
5) Holley or Howell TBI system (sea level to 10,000 feet driving)
7) Shackle Flip (instead of #1)
Now I know that some of you guys have built some serious off-roading rigs. What are you thoughts on getting this GW set up right for "wheeling"? What SHOULD we focus on and what should we IGNORE? As always, money IS an issue, since this is missionary work we're talking about.
Lastly, if anyone has parts that they would like to donate towards this build up, they would be tax deductible. Tim's organization www.hopefortomorrow.org is non-profit (501c3).
Thanks for the feedback on this, guys!
************* HERE'S THE LIST ***************
1) Hydroboost : DONATED by Elliott (thanks!)
2) 4-bbl Holley Street Dominator Intake Manifold : DONATED by Greg Taylor
3) 4" Lift Springs : DONATED by Greg Taylor
4) Drop Pitman Arm
5) Extended brake lines
6) 4" lift shocks
7) D44HD/D60 FSJ Axles or equivalent (DSD) : DONATED (J20 Donor)
8) Locker/Torque-sensing differentials (for stock D44's or D44HD/D60 combo)
9) Rear Tailgate access panel (missing from GW)
10) Big front bumper
11) Big rear bumper : Possibly use the J20 Donor rear bumper
12) Winch
13) Howell or Holley TBI system ... OR ... Off-road 4-bbl carburetor (holley flange pattern)
14) FSJ NP208 23-spline T-case/shifters : DONATED (J20 Donor)
15) Aux. Fuel Tank
16) Good FSJ York A/C compressor and related parts (Tim's is leaking)
17) Safari Rack
18) Rear disc brakes
19) FSJ DSD T18/NP208 combo (instead of # 14) (again a want, not a need)
20) CB Radio & antenna
21) Heddman Headers : DONATED by Greg Taylor
22) Off-road lights
23) Driver-side front fender for NT
24) Rear Window actuator assembly (Tim's is worn out and clunking)
25) Rear driveshaft for NP208 in a GW
26) Bushwacker XJ Pocket Flares for a 4-door
27) HEI dist. for AMC V8 : DONATED by Greg Taylor
************* END OF THE LIST ***************
Hey guys,
1) 6" lift
2) 2" body lift
4) Drop Pitman Arm
6) 4" lift shocks
12) Winch
15) Aux. Fuel Tank
17) Safari Rack
22) Off-road lights
