Old 02-12-2018, 05:03 AM
lastrealcherokee's Avatar
lastrealcherokee lastrealcherokee is offline
Installing HEI distributor in my 4.2 Cherokee.
1983 Cherokee 6cyl auto 139k miles. Now 160k with HEI distributor. Daily driver.
1979 Harley Davidson Lowrider
Old 02-12-2018, 05:33 AM
draglink's Avatar
draglink draglink is offline
Hands down....Going 4bbl. New intake and brand new Holley. It starts and runs perfectly, no matter what the weather. Gained a couple mpgs as well.
'86 GW 6" Rustys, 1 1/2" BJs shackles, 33 BFGs
Old 02-12-2018, 10:54 AM
This thread is great! Keep 'em coming!
2011 Nissan Pathfinder Silver Edition 4x4
2009 Mazdaspeed3 Grand Touring
1979 Jeep Cherokee Chief Wide Track, 401, Full 3" Borla exhaust, Headers, Front Shackle Reversal
Old 02-12-2018, 05:24 PM
Serious Johnson's Avatar
Serious Johnson Serious Johnson is offline
First time that I took the completely stock Wagoneer from South Carolina to my place in Colorado at 12,000'. Altitude compensating carburetor my hairy arse! The cat-con hopelessly plugged and the rig felt like it was making about 25 HP. On one tank it got 1.8 MPG (yes, that's a decimal). The nearest gas station was 18 miles away, most of it in 4-low, so I always kept a 5-gallon can on board. Mt toolset was irresponsibly thin -- had a hacksaw blade but no handle. I wrapped some duct tape around the blade and very, very slowly, over the course of two days, sawed the pipe off ahead of the cat. Then all was good, if loud.
S.J.
"Carpe Mañana".
'83 Wagoneer
360, .030-over, K8600 cam, Crane springs, ported heads, Edelbrock Performer, G.M. TBI, TFI, 3" exhaust,
T-18a/208, D44/AMC 20 w/ limited slip in both, 3.73s, 33s, BDS 4" springs, Rancho 9000 shocks, etc., etc.
Old 02-12-2018, 08:40 PM
J20 project's Avatar
J20 project J20 project is offline
Best switch, hit, slam fix. Dana 44 hd rotors, mounted onto Dana 60 rear hubs, 3/4in spacers w/ Dana 44 caliper brackets. Made the 60 into a pretty cools rear axle.
J20
BP Drivetrain...........
775-537-7918
Old 02-12-2018, 10:25 PM
MadMax78's Avatar
MadMax78 MadMax78 is offline
Not cheap but the best fix
The best fix I did was have a custom front winch bumper made. Used it twice within the first two weeks to save me and my family from a long walk. My wife no longer complains of wasting money on a bumper and winch. As if that was even a waste. Need a rear bumper to match the front now.
MadMax78
78 Cherokee Chief, Wide Track, 360, TH400, Quadra Trac, SOA, 35" BFG KM2, Edelbrock Carb & Intake
Old 02-13-2018, 10:01 AM
ZackN920's Avatar
ZackN920 ZackN920 is offline
Ok, I came up with one... Kinda funny, and really cheap.
Fixing the rear body mounts.
My rearmost body mounts were rotted out. Nothing left to the channel in the body and nothing left to the ends of the rear crossmember. Everything is solid between the frame rails, body wise and crossmember-wise. So I cut an access hole on each side of the body on the inside next to the tailgate hinge covers. Found that there were holes inside that matched the body to the crossmember.
I took some large bolts, some large washers, couple chunks of rubber and made up a plan. Didn't have anything to go between the crossmember and the body... Hmm. Had some 2X4 sitting around. That looks about like what I need. Cut 2 pieces off that would fit, got a crowbar, crawled under the back of the Jeep, lifted the body with the crowbar and beat the wood into place! Walla! Put the bolts, washers, rubber, and nut, torqued it down... NEW BODY MOUNTS!!!
Price, FREE!
Now, if you have to pay for any of this stuff it'd be really cheap, but I had it all laying around.
This fixed the loud banging my rear end would make going over bumps and it also fixed my tailgate issue of only latching on one side. It also OBVIOUSLY raised the back end up so it doesn't look like its sagging or leaning anymore.
AMC 360, TF727, NP229, 3.31gears
rusty-rusty-rusty
The other's
1987 Dodge Dakota LE 3.9,A999TF,3.90gears(Stored)
1994 GMC 'Burban L05-5.7,4L60E,3.73gears(DD)
2001 Jeep Cherokee Sport 4.0,AW4,3.73gears(DD)178K
Old 02-17-2018, 08:54 PM
Old Ironsides's Avatar
Old Ironsides Old Ironsides is offline
Just replaced my POS DUI with a MSD setup. Noticeably more low end power, and better throttle response. Best decision in a long time. 🤙🏽
Grant
'76 J-10, 401 (1406/2131/DUI/RV Cam), TH400, Part Time, 3" lift, 33s, 344K Miles
'75 J-10, 360 (1406/2131/DUI), TH400 QT, 6" lift, 33s, 98K Miles
'77 Cherokee Chief, 401/Th400, QT, 4" lift... Totalled
Old 02-17-2018, 09:28 PM
Oh, doing the sanden conversion and restoring the otherwise factory AC!
Grant
wagoneer front springs donor rigs -- non-jeep Mike D General FSJ Tech 2 03-15-2015 07:56 AM
Are FSJ's Good Wheeling Rigs??? poppatello General FSJ Discussion 14 01-19-2015 11:07 AM
CS144 In 70s Rigs ThisGuyUKnow General FSJ Tech 25 04-06-2012 07:00 PM
Spotted a few rigs! CJ the noisemaker General FSJ Discussion 2 12-08-2010 01:50 PM
Your Favorite FSJ freeincolorado General FSJ Discussion 31 01-09-2010 10:54 PM
