does anyone know anything about the aw 4 TWO WHEEL drive transmissions?thinking about putting one in my old rambler.
aw4 transmission
you will need the wiring harness and control box then figure out how to wire it into the car harness make sure you get the 90 and later set up it does not run through the tps and make sure you get the $400.00 neutral saftey switch with transI\'ve seen gsmikie\'s video for the TH400 and thought it was just awful.watching a guy tear down a greasy pile of metal in a junkyard. it dosent have to be surrounded by water to be an island
