360, stock PS pump with Air Pump too. What a PITA to get to! I tried using a couple of different wrenches but can't get a good angle on it. I couldn't tighten it before installing the pump. There must be a trick someone knows.
How do I tighten the Power Steering High Pressure line at the pump?
82 Cherokee WT ? SFwith Alcan/agr box/Borgeson shaft/ 401/performer/Holley TA/HEI/BeCool/727/ALTAS(2.0/2.72/5.44)/D60 Snofighter(Yukon Zip,hubs,stubs,4.56)/14 Bolt (FF,BF shave,Discs, ARB,Artec Truss)/MTR 37/Corbeau Moab Seats /Hella/tuffy console/sliders/custombumpers&roll bar/WARN 8000/steering brace/CO2 Tank/dual batts/custom TCskid plate
Tags: None
I couldnt' do it without unbolting the pump & pulling it quite a ways out & then i needed a thin open end wrench. You're definitely right, it's a royal PITA!!Mike
78 WT Cherokee Chief Levis Edition, Rebuilt 401, DUI, Hickey Winch, Headman Headers, Dual 2 1/2" Exhaust.
88 Grand Wagoneer - SOA, D44HD & D60, 203-205 Doubler, Rear Disk Brakes, 36" H1 Double Beadlocks
02 VW Jetta TDI - DD
82 Mercedes 300TD
1953 Dodge B4-F 1 1/2 ton stake bed - Restoration Project
I just used a brake line wrench. 3/4 if I recall. Slid right on with no worries.
Might have a different name. Basically like a boxed end wrench with a notch cut in it to slide around the pipe/hose/line to get to the nut.
[ December 18, 2004, 05:46 PM: Message edited by: GaWag ]
i use a brake line wrench, works good77 cherokee s,360, mild cam, headers,3.54s dana 44 turbo 400 p/txfer case,conti 33x12.50x15 9000lbs warn winch<br /><br />78 j-20 original owner, 401+0.30,t-18, dana 20 4:10 gears,8274 warn winch ,<br /><br /> 70 international travelall, the beast, big and ugly, made out of steel<br /><br />ernie
A brake line wrench sounds good but the way the bracket is the nut cannot be reached with one. Does your's have a bend in it? Did they make different types of brackets?82 Cherokee WT ? SFwith Alcan/agr box/Borgeson shaft/ 401/performer/Holley TA/HEI/BeCool/727/ALTAS(2.0/2.72/5.44)/D60 Snofighter(Yukon Zip,hubs,stubs,4.56)/14 Bolt (FF,BF shave,Discs, ARB,Artec Truss)/MTR 37/Corbeau Moab Seats /Hella/tuffy console/sliders/custombumpers&roll bar/WARN 8000/steering brace/CO2 Tank/dual batts/custom TCskid plate
will e i just went out and checked both the 77 cherokee and the 78 j-20, my high pressure hose comes out in the middle of the pump and there is nothing there to interfer with tightening it. i wonder if somebody has changed the bracket.77 cherokee s,360, mild cam, headers,3.54s dana 44 turbo 400 p/txfer case,conti 33x12.50x15 9000lbs warn winch<br /><br />78 j-20 original owner, 401+0.30,t-18, dana 20 4:10 gears,8274 warn winch ,<br /><br /> 70 international travelall, the beast, big and ugly, made out of steel<br /><br />ernie
long term solution might be a trip to the junk yard. I wonder if the change had something to do with the air pump.
Anyone got a picture or two of the 'easy' pre 81 style?82 Cherokee WT ? SFwith Alcan/agr box/Borgeson shaft/ 401/performer/Holley TA/HEI/BeCool/727/ALTAS(2.0/2.72/5.44)/D60 Snofighter(Yukon Zip,hubs,stubs,4.56)/14 Bolt (FF,BF shave,Discs, ARB,Artec Truss)/MTR 37/Corbeau Moab Seats /Hella/tuffy console/sliders/custombumpers&roll bar/WARN 8000/steering brace/CO2 Tank/dual batts/custom TCskid plate
I don't know if snapping a pic will help you, b/c I have an sbc and I'm not sure if the bracket is the same. However, assuming it had a Jeep pump on it when I bought it, the pump is the same as a 74 GMC PU, which you can buy a fully rebuilt unit for less than a rebuilt pump w/o the reservoir.
I'm more than happy to shoot some pics if you want.Ed Mitchell
74 J10
I made a assembly diagram - click on my waggoneer home page. Sounds similar to mine ('85). I wrote out instructions there from my experience. It did require moving the air pump out of the way. If you have a spare wrench and a torch you could make your own ofset line wrench.
[ December 19, 2004, 03:58 PM: Message edited by: nograin ]'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
