This is part 2, hopefully the finale, to the build of my 79 Cherokee.
The plan for her is to have a well rounded rig that can get me into some cool spots for camping, fishing, and wheeling; and to-from work reliably when I want to drive it. But ultimately it will depend on the quality of my DIY paint job. If its too nice, it wont get run up against any trees or buried in mud. The XJ will get bigger and more fun for that duty. If its not nice, at least it will be solid.
This is the first time Ive dove this deep into a project by myself. Ive helped folks do body work, Ive helped folks build motors, and Ive always tried to wrench on my own stuff whenever possible. Im learning alot as I go and am completely open to suggestions or criticisms.
Currently
Sand blasting frame/undercarraige
The "To-Do" list is as follows:
(will try to keep up to date)
Motor
-send heads/shortblock to machine shop
-rebuild
Trans/Tcase (th400/qtrac)
-th400 allison spec HD convertor, 4l80 front band/piston, tci pro rebuild kit, deep aluminum pan (got to pull it apart again and air check the drums)
-Qtrac got a new chain, good looking diff and bearings, and new seals.
Body
-sand blast frame and POR or epoxy paint
-strip undercarraige
-remove driver's lower quarter panel and flare
-weld in new quarter panels
-POR or Epoxy paint undercarraige
-glass in new fiberglass flares
-prep body for paint
-sand sand sand sand
-paint (still tossing colors around)
Suspension
-Rustys 4" spring kit
-undecided on tires, but will be 33x12.5 on the stock wagon spokes.
Any suggestions or questions, please post.
<edited to put to-do list/intro in first post>
Currently
Motor
-rebuild
Body
Suspension
