Old 07-15-2013, 04:58 PM
pyro's Avatar
pyro pyro is offline
Fuel bobber fell in the tank
Tried duct tape on a stick, clothes hanger, a grabbing tool (too small). anyone else run into this? UGH!!!
'81 J10 Laredo 258/T176
'82 Cherokee 258/TF904
FSJNetwork Florida FSJ's Click Here!!!
Old 07-15-2013, 05:06 PM
Rich88's Avatar
Rich88 Rich88 is offline
If you mean the sender float, then no......but if it did, I'd run to my computer and order another sender from BJs immediately.
Only alternative is to rip out the gas tank, figure out how to empty it without causing a hazmat situation, turn it upside down and have fun getting it to roll out the sender opening.
Old 07-15-2013, 05:16 PM
pyro's Avatar
i did order a new one from bj's, however in order to return the old one (w the now missing bobber) it has to be "complete". the tank is out and i tried the shaking method.
Old 07-15-2013, 05:20 PM
Blue88's Avatar
Blue88 Blue88 is offline
Tank dry or wet? Dry I might try a shop vac, given itsa poly tank. Wet, fill it up a little at a time, try to work it towards the sending unit hole? Was it still floating?
88 Grand Wagoneer, 360,727, 229, 3.31 dana 44s. TFI conversion. 2 inch rough country spring/block lift. Pátina and faded wood grain.
Old 07-15-2013, 05:28 PM
pyro's Avatar
its still got a little bit of gas in it...not completely empty
Old 07-15-2013, 05:42 PM
Patience grasshopper...keep fishing. It went in there, it'll come out. Sorry no quick internet downloadable click here app avail. As an addendum, don't fish with anything you could lose and compromise the fishing hole. AKA duct tape...seriously?
Old 07-15-2013, 06:04 PM
pyro's Avatar
put a few gallons back in and dumped it out and the Great Googley MoogleyGreat Googley MoogleyGreat Googley MoogleyGreat Googley Moogleyed thing shot right out. thanks again everyone for the suggestions...now for those rusted filler casing screws in the bed...
Old 07-15-2013, 07:02 PM
JP's Avatar
JP JP is offline
Where horseshoes are not a game
Lol. You better have that thing running enough to drive it to the shop. If I have to come flatbed your butt at dawn your coming to shop day! Its your baby but how am Isupposed to trust you with it if your fishing for bobbers instead of with one..
Glad you got it out. Lol.
JP
THIS RESTORATION WILL BE THE MOST DIFFICULT AND EXPENSIVE THING I HAVE EVER ATTEMPTED TO ACCOMPLISH HONEY, I SWEAR!!!
83 Cherokee
resto thread:
http://www.ifsja.org/forums/vb/showthread.php?t=162358
Old 07-15-2013, 10:38 PM
racegas racegas is offline
Shop vac and gas....
Don't ever do it. End of discussion. Fumes hit electric motor of vac. There are sparks in there. Enough said.
'Robert E Lee'
89 GW White w/Cordovan Interior(daughter's DD)
Old 07-16-2013, 08:47 AM
2ToneBluJ10's Avatar
2ToneBluJ10 2ToneBluJ10 is offline
Shop vac and gas
X2
Take from me...I have seen the carnage...I work for a vacuum cleaner co.
Dave
The few. The proud. The browless.
Somewhere between prissy and pristene
Old 07-16-2013, 12:43 PM
Billygoat's Avatar
Yeah those things fall out, and every plastic one I have is half full of gas (anyone have any extra brass ones around?)
Any way, glad you got it out, I use a 1/2" wide thin alum bar bent into a hook.
I need to drop my tanks again and see if my fell out or filled up again....
tgreese tgreese is online now
You can buy another one.
Look at Ford sites - they sell brass floats there.
Old 07-16-2013, 03:17 PM
WHSII's Avatar
WHSII WHSII is offline
Hack-Priss
I lost one once in my J10 before restoration, I had a solid plastic carb float that I wired onto the wire that the float attached to.
It worked great for five years or more. New sending unit installed now.
If this one sinks, I will look for the hard foam float type material, problem solved.
WH
Herbina 1987 Grand Wagoneer
Old 07-17-2013, 05:37 PM
svining's Avatar
svining svining is offline
Wink The Truth Hurts....
My fuel tank has a water logged brass float in the bottom and a plastic one floating in there somewhere. Their still in there... no problems so far....if I remove the tank for something I'll get them!
Flashlight
"I started with nothing, I still got most of it left"
1982 GW,Stock, No Emissions Equip.
Mallory HEI, AMC 360, Motorcraft 2150
Old 07-17-2013, 07:33 PM
I bent 2 coat hangers into a folding "net" and fished it out. Looked similar to the grilled cheese sandwich, etc campfire cooker I made years ago.
vapor locking JeeplessJohn General FSJ Tech 17 07-25-2017 08:11 AM
Fuel tank, fuel pump, fuel pickup for tbi TexasJ10 Fuel Injection 14 03-19-2013 05:53 PM
1978 Ford Bronco 25 gallon fuel tank swap in J10! msh227 General FSJ Tech 8 10-16-2009 04:33 AM
Help / Vapor Lock Issue key General FSJ Tech 9 04-09-2004 10:54 AM
That leakin gas tank noah's big truck General FSJ Tech 11 04-02-2002 01:38 PM
